  • Replies 44
Hows the lag and day to day street driving on these ebay cheapies? Why would anyone cheap out on such a critical component as the turbo :s
yeah i understand but i honestly dont consider the turbo to be a critical component in the car.. its the other supporting mods like injectors, afm etc that will initially keep the car running healthy into greater power that compliments the turbo to perform well..
there is a bit of lag,, but i love it.. you feel the sudden power at around 3000 (full boost)
general consensus has always been that its all in the turbo n tune...
also, if ur seeing full boost at 3000rpm then you have a small-arse turbo on there. infact i wouldnt put it past the chinese ebay place to have told you a stock RB25 turbo. Its pretty much the only turbo that will make full boost by 3000rpm on an RB25...
This thread has certainly brought the lulz...
Cannot believe some of the stuff before my eyes... Backyard mechanics at it's best. Next people will be filling their tyres with grass to fix flats
Havnt you tried that?? (tee hee)
best backyard fix ive seen pics of was of a ute (in a small african country)where the owner had lost the rear tyre off the rim and replaced said tyre with a garden hose and he was driving it around like that
Edited by StevenCJR31
ive done about 20K on it since install.. it is supposedly meant to run with bigger injectors without further tune (not that mines ecu can be tuned) .. not sure about the z32 (still running a stock afm) . just have the little bolt ons, eg, big return mount ic , bosch fuel pump, series 6 sparkies, pod, 3 inch exhaust..
this chip know's when you've changed the injectors too, i wasted 'big bux' on my ecu! F!
:yes:
so, why are these cheap turbos failing? poor manufacture, poor quality materials, user/installer neglect? do the expensive turbos really out perform the cheap ones?
just because it's cheap doesn't mean it's crap and so far the argument to buy the expensive turbo seems to be losing to me... by about $500.00
I agree, turbos are not really complex pieces of machinery.
Not all cheap turbos are bad, without even thinking Kandos and hypergears are proven performers without the price tag.
as with most things of a "cheap" nature it can be one or a mix of things you have mentioned that cause premature failure. the failure can range from oh my turbos making a funny noise to why is there no boost, right up to i think a piston just shot through the side of my block.
From what I have seen, the particularly bad ebay turbos are not balanced (or balanced at a low rpm to claim a low failure rate) - which is not a hard thing to do and is essential to ensure to the functionality and longevity of a turbo. you simply take it to a turbo shop and they attach it to a manifold in store and spin it right up to it's max rpm to ensure it spins freely and centered. if it is unbalanced they can cut small bits from the inducer or exducer to ensure it i within 0.00000 something of a gram off weight.
all the more mid range to expensive turbos will have slight bits of metal shaved off, thats not a manufacturing fault. If it is unbalanced with a cheap material or a cheap bearing, at a high rpm the fins start rubbing against the housing and anything from some of that dust getting sucked into the motor to a single fin to the entire set of blades flying off at crazy speeds can happen extremely easily.
Some other cheap exhaust housings leave large amounts of space between the exducer and the housing to mask this problem as well as other things and that causes positive boost to come on really late and gives you a useless powerband.
    • Sell it and buy something newer? 😛
    • Better then PooPooG... or is it PeePeeG?
    • The steering wheel on my 97 s3 gtr is a little bit worn out, so im on the hunt for something mint. I notice that this type of steering wheel is on several other nissan's of the era.  Does anyone know if their all identical, or are there slight differences? I feel like gtr tax applies to anyone selling one, but if it comes from any other car the price is much less, even though its the same design.  Chat gpt says the material for the gtr is slightly different and it says gtr on the wheel, but every pic ive seen it just says nissan.
    • I might have to say it.
    • Ahh... it's an early RE5R01A box, that means the pinouts I gave are wrong (they were for the RE4R01A 4-speed box)... I'll have to dig around in my docs to see if I've got that schematic (they used the same gearbox plug, with the vacant pin wired to the direct drive clutch solenoid)...prolly hidden away in a supplement somewhere... ...there were 3 variants of the RE5R01A ~ this early schema was what we called the 'dumb' 5 speed ; it's what jatco called a 'medium duty' box, with torque holding up roughly ~200ft/lbs or so, which was good for NA from RB20/25DE and up to around VG30 output spec. With the RB25DET (and VG33/35 mills), the only options they had was the 4-speed 4AX00 box, which had been beefed up to handle the extra torque (primarily for the VG35, but it also suited the RB25DET mill and others)...and the RE4R03 box in large 4WDs a lot of the time... ...the next variant of 5-speed was redesigned, stronger, and 'smart'...first ones had external TCU with internal (on valvebody) Shift Control Unit, pressure switches, and 2 x TSS...and the last ones had internal TCU+SCU setup, with CANbus control etc etc. @DRoc81 On the RHS of the box towards the rear, there should be a stamped silver ID tag -- what's the model number? Oh...and with the early 5-speeds, the torque converter control solenoid assembly should be replaced as well (31940-60X00)...it's a bit Murphy's Law ....if one has failed, bet on the rest not being far behind ...
