Hi Gurus,
Sorry if this has been covered, but I have searched the interwebs and cannot find any answers.
I did a service on my R33 Series 2 about 3000kms ago with K&N oil filter and Motul 5w40 full synthetic.
I checked the oil level on the dip stick this morning and the oil was already on the low level. There are no leaks that i can see on the engine itself or under the car and i park the car in 2 same locations everyday so it would be visible if it was leaking from under the car.
What could this mean ? or is it normal for skylines to drink oil ?
I understand that its normal for old cars to drink oil but my r33 has only 123,000kms and full service logs and has been stock its whole life.
Cheers
https://www.sau.com.au/forums/topic/402890-drinking-oil/
On an oil change I always fill so that it ends up sitting on the high (hot) mark AFTER the car has fully recirculated the oil.
This means you can then very easily see if the oil were to drop for any reason during service intervals. Mine never does but if the day comes when i do ill know straight away.
Rb's also seem to be a bit safer with a higher oil level, especially if you give them some revs n cornering...
https://www.sau.com.au/forums/topic/402890-drinking-oil/#findComment-6406612
i would put 5 litres into it, not 4.3
bingo.
and just a random bit of trivia to make all us RB owners feel better about the amount of oil we need to feed our beasts. Particularly modified RB26's
- The Lamborghini Aventador needs 13 litres of what im sure is some pretty top of the line fully syn
https://www.sau.com.au/forums/topic/402890-drinking-oil/#findComment-6406717
I just rechecked it this morning and the level seems to be at the same level as when i filled it up(hasn't dropped). I also checked the radiator for oil and it seams to be clear.
I must have checked on a very slight angle, i have read somewhere that on a skyline even the slightest angle makes a huge difference to the reading.
Thx for all the replies.
https://www.sau.com.au/forums/topic/402890-drinking-oil/#findComment-6407898
It's H for HIGH, not H for HOT.
If you replace the oil filter at the same time as you do an oil change, you need to put most of the oil in and run the engine for a few seconds before checking the oil level in the sump. Then add oil to bring the level up to the H mark.
https://www.sau.com.au/forums/topic/402890-drinking-oil/#findComment-6408183
    • CTIS (Central Tire Inflation System) has existed since the 80's. I'm looking into buying a Hummer H1 and they generally included it.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
