I'm currently in the process of removing weight from my weekend and track driven 32 GTR. I've already taken out the air con, rear wiper and some little luxury things that I didn't really need. Now I'm thinking how far I should go with it. Removing the rear seats and sound deadening has crossed my mind but I don't really want to ruin the car I really enjoy driving on the road.
My question is, how far have you taken the weight loss in your street and track driven skyline and did it ruin the comfort when driving on the street.
My weight savers so far, are...
9Kg Ti exhaust
1Kg C/F Rear wing blade
4Kg Ti front strut brace
You've already mentioned other N1 eliminations; but the R32 GTR N1 also dispensed with ABS eh? Are you game enough to remove sound system, speakers and ADR child restraints too?
Depends how much street use, the sound deadening and carpet prob around 30-35kgs+-???, the back seat is pretty light, under 10kgs, they're pretty loud inside with it all out, especially with big exhaust etc, for me for st leave it in, if more track and winning is winning take it out
Yeah i had the interior out for a while, it wasnt only the noise that annoyed me it was the glare off the white in the sun.... I stripped all mine and put a cage in, never bolted it down then had a change of heart and put the full interior back in...
rear steering, I removed the whole thing right to the pump including the pump wheel, about 25kgs
inside sound deadening, 9kgs, not worth the effort on a 1400+kg car and makes the car horribly noisy to drive on the street
Ok I think I'll leave the sound deadening and the seats in then. For a 9kg loss I don't think it'll be worth having all that road noise. Hicas has been removed a while ago. Same as rear wiper, air con including core behind dash (never use air con so removed the lot), rear speakers gone, I 'm planning on removing the abs soon too.
Anything else people recommend to remove on a street and track driven skyline?
Biggest weight saving factor... Dont let girlfriends in the car hahaha.
Terry dont tell Kinberley i said that :P
You would never drop Kimberley off to lessen the weight. And if you did, you also know there'd be ten other guys hanging around to pick her up :)
Abouts time you knew how to spell her name too ;)
Lol > that part, I can tell her!
Baaahahahahah.
Damn fast typing and not checking.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
