Hi Guys,
there's heaps on here about the coppermix twins, but not many reviews on the singles.
I've read the NISMO brochures and know that they're good for around 420ps, but am hoping someone has one in a GTR that can give me a bit of info and their thoughts.
Being a fairly stock car, my 32 putts around with about 280 rwkw on high boost which is rarely used. I'm actually thinking of removing the boost controller all together and just going with the stock solenoid so i think power wise it should be ok.
At the same time though, i want to be sure it'll do the job for years to come, even if i do decide to punish it every know and then. Have read a fair few reviews on them being used in higher power S15's and S14's but am curious about how they go in an AWD
Please no "speak to Jim Berry" comments. I've got one in at the moment and am not happy with it. Just my personal taste.
The twin will be overkill for a stock car, so no point spending the extra k ( or close to)
Cheers
I had one, felt like stock (thought it was stock until pulled it out and got a surprise), took a beating and never had any problems with it. Used it to 262rwkw, never slipped once. You'll be very happy Bobby, go for it. Send a PM to elrodeo666 for buying one - he's a fkn legend and you wont find someone who not only has them cheaper but more importantly he keeps you updated throughout the process from start to finish.
I have to say though, I went from the nismo single to the nismo twin version, didn't regret it at all. While i understand the cost difference, they drive very similar and the twins are so great on a dirty great big launch for when we finally get you on the skidpan ;)
Thanks Guys,
haha, Steve i did have a bit of a play at a texi a few years back ( 1 run with a 3500rpm rev limit ;) )
Yeah i spoke to Marcus last year and will def go with him if i go ahead. His prices were by far the best!
Thanks Alan,
read somewhere that they're quite noisy?
Little bit of extra rattle from the lightweight flywheel, as expected. But nothing extreme.
Mainly on idle and through low RPM range.
You may have heard that in the product warning - http://www.nismo.co....tch/lineup.html
  • The sports clutch discs and light weight flywheels, which are designed and manufactured to increase capacity for higher output and to improve clutch response, may cause the transmission or bearings to make a rumbling noise which is not present when using the original Nissan production parts. Such noise is particularly likely to occur when idling or when accelerating and decelerating at around 2000 rpm. Please be aware that this rumbling is not due to any defect in the parts.
Edited by iwanta34gtr
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
