So after a long... Long time.
MechWarrior is coming back to the gaming world. I'm epically excited and have been watching it for a little while. I'm sure a few of you older fellows would remember it very well and no doubt played :D
It'll be free to play online, but there are Premium options you can pay for and earn extra c-bills and xp etc.
There is a special "Founders Pack" that was announced today as well with varying costs and you get some bonus stuff, more exp/c-bill earning % etc.
Check out the site for more info:
http://mwomercs.com/
Now for the cool shit:
https://www.sau.com.au/forums/topic/402961-mechwarrior-online/
  • Replies 45
Oh wow! Thats a name i havent heard in a LONG time.... I used to love that game!!!
The local INTENSITY used to have full pods setup and they were linked, it was so good back in the day!
looks good. Dont know if i like the idea of having to pay extra for exp and c-bills though.
You get xp & c-bills, just at a lesser rate than someone who pays for Premium.
So if you are really into it, there is a bonus - but like any game where you have to grind a little - you could be playing a lot and not need Premium vs someone who plays a bit less but uses Premium to counter it.
That said as long as the matching system is decent, and not anything like the abortions that Blizzard have used for years, then it should be great :)
I wonder if you can still get the original game to run on PC systems now? I might go search for it just for sh!ts and giggles :D
I managed to get Mech Warrior 2 (my favourite game back in the days of the Cryix 686) 1/2 working on win 7 using D-Fend, athough I can't get sound to work... :dry:
Back to topic: looks sweet, going to give it a try now.
As for the pay for extra xp & credits, looks like a similar model used for World of Tanks (& I enjoyed that game a lot even if the match maker in that game is shit from time to time).
  • 3 weeks later...
No set release date - set for Q3 2012 far as i know.
BETA starts in the next few weeks... Hopefully i get in :D
The more i read and see about this game, the more epic it looks like it will be. Looks to be a LOT of content will keep coming over the first 6-12 months as well via enhancements to mechs, customisation and all sorts of rad shit (all free).
Only issue with that means it could potentially be quite buggy. Lets hope it's not like some other releases of recent times where users are essentially beta testers for 6 months
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
