  • Replies 45
No set release date - set for Q3 2012 far as i know.
BETA starts in the next few weeks... Hopefully i get in :D
The more i read and see about this game, the more epic it looks like it will be. Looks to be a LOT of content will keep coming over the first 6-12 months as well via enhancements to mechs, customisation and all sorts of rad shit (all free).
Only issue with that means it could potentially be quite buggy. Lets hope it's not like some other releases of recent times where users are essentially beta testers for 6 months
You will get into beta Aug 7th as above.
The clans will not appear in MWO until after a year after release bringing with them much awesome content.
Already runs pretty well and looks very good.
  • 2 months later...
*raises hand
Jacob (Div) is on there, as is Cozi (my bro).
I've really gone off it actually to be honest from the BETA point of view. It was so limited during with mechs, weapon imbalance(s) and so on. A whole heap of features have been added over the past month (i've been reading the details notes each time) but I've been so busy with other things I didn't have enough time to do any testing justice.
It took so long to grind out a XL380 engine for instance (5hrs easily) that it was just a painful kunt being reset each week and losing it. Made it really hard to experiment with the larger Mechs and varying builds that could ultilise speed.
Also not having many friends to play with - there were a LOT of retards, more than any other game, who just didn't grasp the basic concepts of the game and mechanics. You'd get morons who'd run off along and get stomped by a group lol. Or jenners who wouldn't scout and just hang around with the Atlas or my Cata/Awesome LRM boat which totally defeated the concept of doing it and i ended up getting raped :D
Concept is still awesome regardless and I think if we could organise a group and play together whilst on Team Speak it would be epically awesome with people playing their dedicated roles in the game and outfitting mechs to compliment a group purpose etc. Also the overall commander thing (not sure if thats in yet?), that concept will be great as well.
Once they add planets, missions, proper clans/mercenaries the whole struggle for power - It will truly be a fking sensational game as that is where it will blow other current games out of the water from a overall involvement factor. I feel that is still long a while away however.
If a few of you are keen to team up regularly then I'll make an effort to get on again, otherwise i'll stick to smashing master league in SC2 lol :D
I'm in it too, haven't played for around a month though. Only having one game mode and 3-4 maps ended up getting boring. It probably doesn't help how similar a lot of the gameplay is to WoT either, considering how over that game I am.
I don't really play it because I have friends that are very reliable judges of games playing it so I don't bother to make the time while it's beta.
WoT is looking pretty sweet after v8.0 too and with my tranfer to SEA I lol'd to find I am well inside the top 1000 for all players on that server.
I should really just not buy any special versions of games ever, or pre-order. Turn out to be very average far too often and then the ones I don't buy turn out awesome. Definitely need a time machine or a 'actually your game is shit, my money back please, kthx'.
I got a Beta invite yesterday so will fire it up tonight.
I'm in the Hawken Alpha and, well, it's utter shite. Am keen to get into MW.
Hawken is alright but needs a lot of improvement much like MWO did 6 months ago
  • 4 weeks later...
Just started yesterday the game has potential, at the moment I can see myself getting bored quickly. The audio feels like its lacking and the distance blur is a little over the top.
Are there any advanced guides out there, no idea what I should be aiming at.
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
