Genuine HKS GT-RS Kit. .73 rear A/R + 1Bar HKS Actuator
Asking price: $1,750 ono. (open to geniune offers)
This is the perfect turbo upgrade kit for the RB25, Straight bolt on, to standard manifold and dump. spools as quick as the standard turbo,
This turbo kit is worth approx $3k + Taxes from japan. It comes with all paperwork, warranty papers. and documents, original receipts and all fittings that come with the kit including original packaging.
The turbo kit is has been removed from the car and has been carefully cleaned and all sealed up in box.
The car was making 255rwkw(350hp atw) on 14psi. I have only ever ran it at 1bar because it was fast enough, but it is good for 22-24psi(approx 400atwhp with supporting mods). This is a low km turbo and its condition is near new. Theres no shaft play, and the turbo kit is ready to be bolted in. Welcome to inspection and professional scrutiny.
The car has never been thrashed with the new setup, and management has been taken care of by a closed loop Apexi LM AVC-R + PFC. it was driven rarely and there has been no problems what-so-ever.
Reason for selling: I am selling the turbo because I am upgrading due to my new 30/25 setup. It is what i say it is or your money back.
Shipping/insurance costs included in sales price.
no timewasters or bullshitters please.
Located in Brisbane, QLD
Contact: Dale on 0432279166 or 0419745910
http://img850.images...hksgtrskit2.jpg
http://img809.images...hksgtrskit3.jpg
http://img267.images...hksgtrskit5.jpg
Edited by SilverECR33
https://www.sau.com.au/forums/topic/402975-upgrading-your-turbo-on-your-rb25/
awesome looking kit mate, best of luck with the sale. If I wasn't jobless and broke and didn't own an auto and it didn't have a big-ass dent in the side I would definitely go for this. Just out of curiousity what's that 4-way joiner in the bottom middle of the pic for, the one that's sitting on the pack of hose clamps?
thats a good question for HKS :) . I never used it. I'm pretty confident its a vacume T. I did mine a little different and didnt retain the standard intake manifold and cooler pipework. So I didnt need it.
Cheers
T piece for boost feed to the actuater
i was thinkin the same thing thanks
Suit RB20?
it should yes. as long as ur flange and the dump are correct type. which i think they may well be.
Are the splitfires in the pic for sale too?
No im sorry Im keeping those
Suit RB20?
If I had the cash it would already be in transit toward my RB20
If this it true it will be ok on an RB20, I had a 25 turbo on my car when I bought it and it didn't feel laggy.
Edited by cherring
I can attest that this is a perfect turbo for a RB25 daily drive... Super responsive 250rwkw+
If someone buys this, message me if you're after a custom coil pack cover to go with the turbo (see pics below)
I'm switching to RB26 covers, so it's available for sale.
Engine Pic (HKS GTRS Coil Cover)
    • That's the thing. Especially at idle, changing the cam angle by that much could be spewing more fuel out the exhaust courtesy of everything happening that bit later. More fuel also means more air (if the fuel didn't burn, then neither did the O2) and so the O2 sensors can start to tell interesting but misleading stories. And the specifics of what is happening could easily be affected by everything else you changed as well. And it could be dynamic, where a few revs more or less could somewhat change how the engine is breathing.
    • Good idea on the temp probe. The mv readings of the O2 sensors are very similar to one another, as is the injector pw. I went through logs in the past to see if there was a discrepancy and there is. Because they alternate up and down as narrowbands do.. they do often 'switch' as to which one is more. They were never 20%+ (more like 1-2%) so it's possible the difference between 20 and 15-17% is a similar discrepancy to 2.0% and 1.7% which I wouldn't have really noticed in the past. We did think about spacing the strut brace. Unfortunately the ~20mm that the GTR brace is lower than the GTT brace is effectively what you need to clear the vents. Moving it up would make it very uncomfortable, but it's plausible that 10mm is a unhappy medium between both hard places... The good news is.. using MR HAMMER it was actually pretty easy to bend back the bent bits to make sure the guard and headlight/new headlight tabs line up right. Yes, we used a R34 GTR guard to make sure the bolt holes all lined up with a known straight guard. As above, you can see the side skirt and the GTR guard are not meant to play together, but everyone seems to think this is a simple fix to the point where nobody who has had these talk to one another mentions how... ...so I'll just assume they know how to fix it when it comes to paint jail time again. Whoever they are. Nobody returns my calls. There's so much changed with regard to the ECU and the car.. that the next step really is to connect the scanner and attempt to drive the thing. It'll be pretty clear pretty fast how in or out everything actually is...
    • That's nasty! I think there is perhaps an inherent problem is using elastomers in such environments. The whole thing can and will get quite hot, and elastomers are not famous for their temperature resistance. On top of that, if the components are cast rubber or urethane and so on, there might be QA/QC problems with bubbles or voids in the material that could critically change their performance. They might just tear apart after being squished (presuming that any elastomers are used in compression rather than tension, I'm thinking that you squeeze one with a void in it and it tears the wall of the void to the outer edge of block, then the next time it extends or otherwise twists, it just gives up). This is all purely hypothetical, but it makes me wonder if the things that they have put into it to make it nice to use/live with are perhaps going to cause occasional failures like this. I wouldn't be getting up in arms over it, unless there are many repeats. I have personally ruined an Xtreme clutch - just an HD thing. I can't remember if it was still behind the 20 or was after the 25 went in. But it inverted some of the retaining spring/clip things around the outside. No-one could explain it. It wasn't thrashed, there wasn't heaps of torque being put through it, and there were no obvious problems other than the above. They were quite concerned by the event so they replaced it even though it was a few years old, which was very nice of them. As far as I am concerned, these things happen with clutches.
    • Any damage to the box/input shaft?
    • Hey there Mate , I just got my local guy to install it Waterhouse Performance, Penrith (specialise Nissan/Datsun and other performance cars) , you can do it yourself if you like , AMS has instructions on their website.  Cheers Pac
