Genuine TE37's 17x9" Dark Blue +6 Tyres.
17x9" TE37's that came on my car when I imported it from Japan in 2005. No they are not fakes, they're the real thing. Very light with Rays Engineering & Made In Japan stamped on the back and of course are very light.
Not too sure about the offset as the stickers are long gone but they are a pretty aggressive offset as per the pictures of them on my 32GTR. I don't know if they'll fit under your guards on your car.
Are a little blasted and also have some minor rash.
2 of them have RE540's 255 40 - bald.
Other 2 have new Michelin Drice 235 45 on them, also another two new Michelin tyres unfitted.
No centre caps.
Reason for sale : Have moved to wider TE37's.
Location : Hawthorn East, Melbourne. Will ship if buyer arranges courier.
$2000
Contact  : 0425 730 031
If they are in fact 17x9, i'd put money on them being +22 or +15.
I was under the impression that R32s struggled a bit with +12 offset, but the owner did say they're quite aggressive at the moment.
  • 4 weeks later...
wow just found this post again, from when I thought i'd sell these wheels.
Ends up they're 17x9 +0 (yes, 0 offset TE37's - they stick out further than my +12 9.5 TE37's). Long discontinued by Rays.
Glad I kept them. The call for another set of TE37's is strong. Anyway .....back to my beer.
4 minutes ago, Mohsen said:
youre a monster
yeah, I realised now I defiled them, seeing as they were Mag Blue.
I have plans on getting them professionally sprayed back to their original colour.
5 minutes ago, niZmO_Man said:
Sorry, I should have said "pretty much the same as" :D
I should also add that when Racepace took the front brake setup off to replace them,, they discovered a dodgy spacer setup (had some sort of Brembo setup when I got the car from Japan). Hence the front wheels now sit slightly more into the guards then in that photo.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
