For sale is my 1998 Manual, R34 RB25GT-T(NEO) Coupe.
VIN: 6U90000ER34001079
REGO: XCH836
I was the 1st owner in Australia 4 years ago and it had 80,000km on the clock when i got it. Currently it has 138000km.
The car has never been boosted and the modifications are not as over the top and are as follows:
3 inch turbo back with high flow cat to a 3 inch cannon. (Sounds Great)
Apexi Pod filter,
Replaced OEM Clutch with an Excedy Heavy Duty Clutch only 5000km ago.
2 din touch screen LCD CD/DVD player with full GPS, Blue tooth, and reverse camera with 6 in splits front and rear.
Turbo Timer.
Deleted spoiler (No holes) with factory option nismo side skirts.
4 New tyres only put on 2 months ago.
Upgraded drilled and slotted rotors on the front with extreme motorsport pads. (20000km ago)
Replaced coil packs 30000km ago, no problems.
100000km service completed with new water pump, gates belts and timing belt at 120000km.
Oil changed every 5000km and filter every 10000km.
Will be selling with a road worthy and full 12 month rego (Runs out on the 1st of July so I will pay it)
Interior is well looked after non smoker, not burns or scratches, comes with original floor mats and will not disappoint
The only cons about the car is there is a small dent on the bonnet that happened 2 months ago, its the size of a 20 cent piece as the photo shows and the usual stone chips for a car of this age. Was quoted $400 to get it all fixed and this can be negotiated with the price.
Its a great car and only selling because I getting married and unfortunately need something a little more practical.
This is a great car and is priced to sell. The price is negotiable but please no time wasters. The car can only be viewed on the weekend due to my work commitments. I may not be able to answer my phone so please leave a message or send me an email and i will get back to you ASAP.
Roadworthy will be provided with a $500 deposit.
$13,000ono
Call me: Ben
0409350879
or email:
[email protected]
The car is located in North Ringwood, eastern suburbs, Melbourne and i will give out my address if you want to come and look at the car.
The car is also advertised on carsales.com.au
Just a quick check of eBay and they are from $200 for just the spoiler and $400 with a boot. The car is pretty cheep so with your left over cash you could put one on quite easily :)
Hey man, mistakenly posted a congrats on sale because I sorted carsales wrong and thought you sold her. She's a beaut btw, was very impressed. I'm still waiting on my cash -.- good luck with the sale buddy she's sweet.
Edited by jukic.j
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
