I've had my 33 for about 18 months now and have read everybodys posts (with envy) when they have bought their mods etc.. Now its my turn.
I had a Nismo cluster and centre gauges put in last week. I ordered a Power FC through Japanese Import Parts which should be hear soon and ordered a set of Volk TE37's from Dave which will take a bit longer but well worth the wait.
I may even get some cam gears installed depending on finances.
Waiting is a pain in the arse.
Alan
https://www.sau.com.au/forums/topic/40303-it-has-begun/
Yes, I like to think that James.
What it means is the distance from the inside of the wheel where it touches the hub to the inside of the rim at it's furthest point (I'm pretty sure). You'll notice the difference between mine and Andrews. His look a lot more deep where as mine dont as the offset is a higher value. It's so they dont hit the calipers and fit under the wheel arch correctly. If you used the same ofset on a GTT as a GTR they'd hang out the arch's.
https://www.sau.com.au/forums/topic/40303-it-has-begun/#findComment-827327
Alan,
Where did you pick up the nismo dash from? not that it matters now but I can get pretty good price on them new now..
Also, can I suggest if your going to get cam gears, do it before you tune the pfc.. otherwise you'll keep spending money on tunes everytime you put something on which can become costly.
https://www.sau.com.au/forums/topic/40303-it-has-begun/#findComment-827416
    • Give the fluid a really good flush, then go do the same track again. Report back too please
    • I think most of the benefit there is really from the battery as well, having 1 kWh or so means you don't need the engine running at idle to run the AC, when the battery is depleted you can run much higher idle to charge the battery at a lower bsfc point and then shut it back down, you can regen on braking to recover some of that power too. I can't imagine the benefit from only running the compressor as much as needed is huge if you're mostly only running the AC on hot sunny days where it really needs to work hard to keep interior cabin temp under ambient.
    • Yeah, unless you're doing it by the book, your data is probably not useful. Boiling point drops rapidly with only just a little water in it.
    • How hard are you tracking it? I have 378 in front and 355 in the back with decent pads and my brakes were spongy after a decent session with lots of braking. It was a short track though but got up to around 190-200 max. be keen to hear. Mind you, I havent flushed my fluid so thats probably part of reason.
    • Awesome thanks for the reply Man! I already plugged up the back just cause I can’t take a chance on it leaking on me again haha. But i will fab a catch can with 2x for the cam covers and a lower one for the sump vent.    Now as this will drain back as well , Is there any concern I should have of the oil being drained back. I don’t run e85 or anything .   2nd question is, from the picture does it seem that my sump fitting is above oil level? Silly question but I rather have someone’s experienced opinion lol
