Hey, just wondering what the average amount of boost you can run (standard computer, 25 turbo, cooler, exhaust) before the car will hit fuel cut & not boost properly.
I’ve just installed a boost tee which is set to 14 PSI & I’m wondering if it’ll likely need adjusting to a lower boost setting.
Cheers,
https://www.sau.com.au/forums/topic/403035-rb20det-max-boost-before-fuel-cut/
rb25det NEO cuts out at 14-15psi. thats when mine cut out.
and at the 15psi mark, it will also go into R&R around the 5k rpm mark every now and then.
mine ran into 2 problems when i hit 15psi, it either cut out completely and it felt like i drove into a wall when the fuel cut out,
or the other problem was it just stopped accelerating past the 5k rpm (i could keep foot on accelerator but it would not go past the 5k mark), i think the R&R kicked in then.
The ECU decided at random what it problem it wanted to choose.....
so i replaced the stock ecu with a power FC and run between 14-16psi depending on the day
Pretty certain RB20s don't have a fuel / boost cut mechanism. Other than the ceramic wheel shattering if you consistently run more than about 14psi boost.
pretty sure you are right on this.
best thing is to put it on the dyno and see what is going on with the afr's to make sure it's not leaning out
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
    • Ah yep. I asked a auto electrician about getting a cheap rebuilt alternator vs a new one. He also said he used to it back in the day but it ended up costing similar to what a new one would and recommended getting a new one,.
