So I went and ordered one of these.....
http://www.ebay.com.au/itm/Realtime-Car-Tracker-Vehicle-GPS-GSM-GPRS-Tracking-Device-System-Spy-Alarm-Tool-/270867534485?pt=AU_Car_Parts_Accessories&hash=item3f10f69295#ht_6131wt_946
without really doing enough research into how to wire it into the V36 ignition and/or fuel pump. Installing the unit itself along with the antenna's etc will be a piece of piss, but the ignition and fuel cut are over my head. Knowing how complicated the electronics on these cars are, I am now a little worried. Once I discovered that disconnecting the touch screen 4 wire ribbon cable from the main board, actually renders the entire A/C controls and steering wheel controls inoperable, I knew that I was in for a tough time with this car.
I have been looking through the 10000 page G37 service manual and have found a few wiring schematics and such but am not the most electronically gifted individual out there, so these don't help a hell of a lot.
Can anyone point me in the direction of where to start or at least give me an idea of whether this will even be worth attempting? If someone has a photo/image of which wire/s I should splice into for the ignition and/or fuel pump it would assist greatly.
I will be pulling the dash apart for the 10th time this weekend to finish off (hopefully) what may be a credible alternative for those wishing to get Australian Navi etc. on the OEM touch screen, and would like to have a go at installing this tracker device at the same time.
Thanks
Al
andrew,
how did you guess...
if you are even considering doing this - fuel pump would be the only place I would EVEN THINK of cutting. forget about getting ANYWHERE near the inner workings of the BCM unit..
I wont lie and say that I wasn't directing the question towards you Chris, I just didn't want to be too direct ;)
So can anyone direct me towards what to pull apart and which fuel pump wire would be appropriate to make some minor modifications too (read: cut in half)? The unit comes with a relay and everything is all set up to simply splice into the wire, I just need to know which one and how to get to the bugger.
On another note. With the amount of times people ask V35 and V36 questions on here and are simply forwarded onto you Chris, I hope that you are taking advantage of this fact, $$$$$ wise!
to be honest - I do not see $$ out of it. I do get a lot of can you change the language in a V36 questions to which I reply no and state unless you have a decent amount of $$ not to bother. that is usually followed by why can't I do this after reading a forum from overseas..
when it comes to spare parts now. thats another story. I can do those at will ex japan.
grab the V36 FSM and look for the fuel system section. that should tell you.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
