Parts available from 29th June
Pics and prices to come low Kim's r33 big turbo set up motor box Coilovers body kit plus more
All body panels straight in great condition
Pm your pre orders
Located Redhead nsw
1995 series 1 marroon
Just moved both my cars will be shipped next week i will upload pics and prices then
0402555849
I have a complete car here is the list if there is anything that you want thats not on the list just pm or call
Mechanical:
rb25det comp tested runs perfect will have clip of it running before removal. Comes complete with aftermarket coilpacks ecu wiring all accessories stock turbo but no turbo manifold $1200
Highmount turbo set up. T04e with manifold proboost external wastegate with screamer, braided lines, dump pipe,front mount plus all pipings ,clamps hks style bov $1350 All 18month old
r33 gearbox perfect conditon $1200
tein superstreets coilovers just over 12 month old $850
Complete front brake set up including hubs and knuckle $350
Rear set up including handbrake cables and hubs $350
R33 gtr radiator $200
Tight lsd $250
Rear shafts $65 each
Tail shaft $80
Front controll arms lower $45 each
Front caster arms $20 each
Rear complete arms $60 a side
Front and rear stock sways $45 each
P/s rack $80
Stock wheels 2 tyres ok missing 2 centre caps $200
Brake master cylinder $35
Booster $40
Rear supframe $120
Anything else just ask
Body:
Straight as guards $100 each
body kit included front bar which is cracked but can easily be repaired , side skirts and rear bar in good conditon $400
Rear boot with wing $200
Gtr boot with wing $300
Bonnet very straight $250
headlights will be glass polished before sent $250
rear tail lights $65 each
Straight as doors with windows regs no handles or trims $100 each
Mirrors $45 each
Interior:
neat front seats $150
Rear seats $75
door trims $50 each
stero surround $50
Cluster $100
Centre console $50
rear view mirror $35
Seat belts Front $45 each rears $60 the lot
autometer boost gauge with cup $45
turbo timer $35
Rear trims $25 a side
Pillar trims $15 each
Scuff panels $20 each
Dash $80
anything else just ask
0402555849 or pm
Located newcastle but can help with freight
Edited by runkos
Some new pics and prices
Unknown jap brand 3 inch front pipe $70
3 1/2 inch cat back into 4 inch diff back stainless exhaust with cannon $300
Tein non adjustable suspension $450
Manual conversion kit $1500
rb25det motor ecu wiring aftermarket coilpacks with t04e turbo set up including front mount and piping $2200.
I have a clip of it erunning before removal
Fuel flap $15
Boot rubber perfect condiotn $20
Skyline garnish $35
Rear window lower trim perfect condition $35
Spare tyre $50
Factory jack no handle $25
Edited by runkos
S1 R33 GTST Auto speed sensor by any chance?
No sorry mate
Will the hub + knuckle fit an R34 GTT?
Mine is broken and I can't find another.
Not sure have you asked any of the guys on here in tec section?
Motor sold
gearbox conversion sold
teins sold
Gtr boot sold
rear bar sold
rear seat belts sold
Still have heaps of interior bits, seats,driveshafts, wheels, exhaust , door skins, bonnet , passanger guard, skirts, gtr radiator and a few other bits and peices
Stolen car kit Boot lock , door locks , complete steering assembley with ignition barrel and key $110
  • 4 weeks later...
hey mate you got a pic of that boost gauge, i need a cheap one for testing! also is it psi?
psi mate
will you do 2 wheels for 80 cash?
Wheels sold
    • Thanks Murray, appreciate the advice, a few things to think about now 😀
    • After my million questions, I'll throw in my 2c now.  If I was in your shoes, I would buy the best/most modern ECU available. A Nexus S3 would fit the bill. It is highly likely that this ECU will last the life of the car, regardless of whatever ECU manufacturers develop in the future. Modern ECU's are amazing and will still be amazing in 10 or 20 years time. If you can get e85 relatively close to where you live, I would buy a flex sensor and size the injectors to run e85. I'd go a Walbro 525 fuel pump with relay wiring kit.  Turbo wise, I'd hit up HyperGear and get a pair of the biggest bolt on turbos.  Now for the safety side of things, I'd have the tuner setup the tune to be very soft/safe on 98. Then on the flex tune, a lot of the timing can be put back in on the top end (I'd run full boost on both tunes, but manipulate the power with the timing). This also has the benefit of hopefully delaying the, "bored now, need more boost" that comes with owning a modified turbo car. If you spend most of your time on the 98 tune, the few times your on e85 will hopefully stay special/fun.  The bad news. As your paying for labour and tuning, I don't think this will happen with $10,000. This might be the motivation to learn to do it yourself though, that way instead you'll have the built car and change from the $10,000
    • Cheers Duncan, on club reg and very much a weekender, don't drive it all that hard and don't intend to go overboard at any point in the future too. In my 40's and quite mature driver, just want that little bit more from it 😉 Sounds like, after ensuring everything is in good condition, ECU, Injectors, Fuel Pump and a set of turbos is likely to be my path forward.
    • 15 years is not too long to hold onto something like that, right?
    • Hey man,   By any chance you still have sunroof for sale ?   Thanks
