Wrecking Modified R33 Gtst High Mount Turbo Coilovers Plus More
I have a complete car here is the list if there is anything that you want thats not on the list just pm or call
Mechanical:
rb25det comp tested runs perfect will have clip of it running before removal. Comes complete with aftermarket coilpacks ecu wiring all accessories stock turbo but no turbo manifold $1200
Highmount turbo set up. T04e with manifold proboost external wastegate with screamer, braided lines, dump pipe,front mount plus all pipings ,clamps hks style bov $1350 All 18month old
r33 gearbox perfect conditon $1200
tein superstreets coilovers just over 12 month old $850
Complete front brake set up including hubs and knuckle $350
Rear set up including handbrake cables and hubs $350
R33 gtr radiator $200
Tight lsd $250
Rear shafts $65 each
Tail shaft $80
Front controll arms lower $45 each
Front caster arms $20 each
Rear complete arms $60 a side
Front and rear stock sways $45 each
P/s rack $80
Stock wheels 2 tyres ok missing 2 centre caps $200
Brake master cylinder $35
Booster $40
Rear supframe $120
Anything else just ask
Body:
Straight as guards $100 each
body kit included front bar which is cracked but can easily be repaired , side skirts and rear bar in good conditon $400
Rear boot with wing $200
Gtr boot with wing $300
Bonnet very straight $250
headlights will be glass polished before sent $250
rear tail lights $65 each
Straight as doors with windows regs no handles or trims $100 each
Mirrors $45 each
Interior:
neat front seats $150
Rear seats $75
door trims $50 each
stero surround $50
Cluster $100
Centre console $50
rear view mirror $35
Seat belts Front $45 each rears $60 the lot
autometer boost gauge with cup $45
turbo timer $35
Rear trims $25 a side
Pillar trims $15 each
Scuff panels $20 each
Dash $80
anything else just ask
0402555849 or pm
Located newcastle but can help with freight
Edited by runkos
Some new pics and prices
Unknown jap brand 3 inch front pipe $70
3 1/2 inch cat back into 4 inch diff back stainless exhaust with cannon $300
Tein non adjustable suspension $450
Manual conversion kit $1500
rb25det motor ecu wiring aftermarket coilpacks with t04e turbo set up including front mount and piping $2200.
I have a clip of it erunning before removal
Fuel flap $15
Boot rubber perfect condiotn $20
Skyline garnish $35
Rear window lower trim perfect condition $35
Spare tyre $50
Factory jack no handle $25
Edited by runkos
Motor sold
gearbox conversion sold
teins sold
Gtr boot sold
rear bar sold
rear seat belts sold
Still have heaps of interior bits, seats,driveshafts, wheels, exhaust , door skins, bonnet , passanger guard, skirts, gtr radiator and a few other bits and peices
Stolen car kit Boot lock , door locks , complete steering assembley with ignition barrel and key $110
  • 4 weeks later...
 Share
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
    • FWIW, the Sutton Road facility is a good one, they have a wet kidney skidpan and a dry area as well as the back track....the club hired it a few times back in the day The clover and wet pans at Eastern Creek are the only ones I still know of in Sydney, that place is always expensive but different clubs would run different prices/formats There used to be a place called HART at St Ives, not sure if that still exists. We used to hire the runway at the tafe at schofields for dry motorkhana, not sure if anyone still does that. And of course that lovely one at Oran Park that is now a housing estate....
    • Sounds like you are trying to escape one abusive relationship by getting into an even worse one. It is possible to change your life if you want to
    • So, I did a skid pan last Friday at SMSP which I totally sucked at. I'd like to get better at this but it was $350 and I probably got about 20 mins on the pan over the 4 hours I was there which is just not a great ROI.  I don't have a LSD in the car yet, that will happen before I go again. I was struggling to get the car to be consistent and I think it was the open diff. I also struggled to maintain any control at all once it did step out. More practice needed.  I found this one but it's a good 7hrs round trip for me. https://www.fifthgear.com.au/course/advanced-skidpan-training Are there any others that people have been to around Sydney?
