Hi Every1,
Have spent a while on the phone to Nissan parts trying to work out the part number of the front face / finisher I need for my air con unit.
The front / finisher that I currently have on mine has a crack in it, so I need a replacement.
I am aware that there are two different types of finishers (as per picture), I need the larger version.
Nissan have provided the below two part numbers -
27570-AA401
27570-AA411
Does anybody have access to a Nissan parts database or similar and able to clarify which one I need? Nissan said their system does not clarify the difference between the two.
I have done some googling and found the following link - http://nissan.epc-da...ody/272/27570M/ It says that 27570-AA401 is for the NAVI unit version? If so, I believe this would be the smaller one? But im guessing as there are also other part numbers for other finishers? So its hard to tell which one is the correct one, there appears to be a few variations.
Thanks in advance for your help.
Edited by iwanta34gtr
Have done some more research and have found the below part numbers appear to be what I am after -
27570-AA411
27572-AA411
If anybody knows the difference between the two?
Have attached links to the sites I found the info on, they are translated from Japanese so may take a little while to load.
http://www.microsofttranslator.com/bv.aspx?from=ja&to=en&a=http://minkara.carview.co.jp/userid/679755/blog/16705342/
http://www.microsofttranslator.com/bv.aspx?from=ja&to=en&a=http%3A%2F%2Ftkomatsu.cocolog-nifty.com%2Fblog%2F2010%2F05%2Findex.html
Hi All,
Have had further discussions with Nissan Australia and part number 27572-AA411 is not listed in their system.
So, by process of elimination - this leaves part number 27570-AA411 as the correct number.
If anybody can confirm or has any additional info before I place the order?
Apologies, could not edit any of my original posts.
Thanks.
