  • Replies 59
Just sold all piping and vaccum hoses for BOV etc But still have the cross-over pipe and the bov itself. An update on other parts:
Rear brake discs and calipers
Dash and rear seat (both have minor marks)
Heaps of interior bits including sun visors, lights, plastics, some trim etc
Power steering fluid resrvoir
Window glass
Windscreen wiper motor
Centre console
Rocker covers
Fuel tank door thing
Boot cable and lever (to open boot from inside)
And various other Misc parts which I want to get rid off - 0420 593 194 NEED IT ALL GONE YO!!!!
  • 4 months later...
  • 4 weeks later...
  • 4 weeks later...
  • 4 months later...
Hi mate
I know im bumping an old thread here but I am after a rear seat and trims, the parcel shelf and the carpet. do you have these parts left?
cheers, Rowdy.
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
