I can vouch for the Greddy. On my previous setup I had one holding boost dead-straight for my HKS GTRS @ 20 psi. Can't remember when full boost was achieved, but it was scary responsive.. Boost would fluctuate between 19.8 - 20.7 psi when on full song. (According to boost gauge)
is 6k rpm scary responsive?
Don't rule out timing, the front of the exhaust cam can get chewed out and timing will move 10-15 degrees.. Tends to be less consistent though, will go like a shot one day and a bucket of crap the next.
Don, I think I have about 10mm now...the outer end of the actuator just touched the boss that the flapper shaft/spindle passes thru. You'll see what I mean when you check yours ;)
Checked mine and the outer end of the act sits just before the middle of the pin giving a measurement of hole center on the act to center of the pin about 7mm.
So basically with 9psi acts with less preload, we have about the same response......EBC time!!
And these turbos were proven time and time again, and as a matter of fact seen some really shitty response times for -7s as well on paper too, so its just a matter to tweaking to get them up to scratch so dont worry
There appears to be different understandings of response here....
1. The initial time it takes the turbos to spool up from idle speed during take off, and,
2. The time / delay for max boost to be achieved when you're in the turbo's working rpm band, above say 4000 etc. Eg, when you're on the track, holding 4500 around a corner and then power back up for the exit.....example 2.....you're at 4.5k, you put flat down, how long does it take to make full boost = level of responsiveness.
What we "should" be talking about in this thread is No.1....how long it takes for the turbo to get everything going hard from idle rpm. I guess it shouldn't reeeeealy be called "response" just by itself...maybe initial spool up time would be a better way of putting it :P :P
And yes, big singles can be very "responsive" up top when there're plenty of fumes going round....but I don't think you can beat the responsiveness of small twins or the stockers. When you're up it they on max in a split second - awesome on the windy roads ;)
Haha I see...yes, I think we're going to go down that path ;) I'm not gonna wind on any more pre-load for now....I need to see where this thing boosts to now without bleeding anything off (bleed valve is closed, may as well take it out). I reckon the 10mm on mine will make it boost to exactly 18 pounds or so - if it goes over, I'll have to wind some preload off :no: ....ultimately I'll have to maybe wind some off again anyway so EBC can do some controlling up there as per XKLABA's recommendations.
My 9's love the twisties. When are you getting the final tune and stuff?
ASAP mate. Right now I've been ganny-ing around with front prop shaft removed because tuning mob killed the front diff (somehow). Hope to have it in soon and then it's off for a tune once more
...also, there's the EBC....wondering if I should just putter around some more and get that as well before tuning
Yes, I would think its a good idea to let the tunner play around with it and get it all set up.
Haha I reckon anything would look good on the graph right now....they tried to tune it with the wastegates flapping in the wind - dumbasses! I mean hell, what tuner does that? "Hmmm....turbos are laggy....lets not check for mechanical issues and crank up the boost instead" GRRRRRRRR!!!! :domokun:
Right now they'd have a graph that would similar to a GT30 except a bit fatter down low...just need to have the whole show shifted forwards by another 500rpm and then I'll be a happy chappy!
So what are your plans Don? Do you have any graphs? Mine was so pathetic that I didn't take a copy....it's flat and gay and would just remind me of when I spent all that money for nothing :P
Am quite motivated now...just came back from a drive that had a highway stretch in it where I loaded them up a bit in 3rd up a hill.....expected just the normal low boost but they instead ramped up to what would have been (I backed off) around 16psi at 4000 ;) Can't wait to get it tuned so that she'll ramp up like that in the lower gears too!
tommis85: with your foot pump hooked up what pressure did the wastegate start to crack open? how much preload have u dialed in (1 full turn is equivalent to 0.8 mm) and as a result what is your peak boost.
Cheers
    • Welcome back mate ,I also joined in the early 2000's , since then I have been in and out a few times depending if I had a skyline in the garage.  I have the another one now , so signed up and back with the SAU team.
    • I used "different strokes for different folks" quite pointedly as honestly, there is no wrong when it comes to choosing what you like.  I always day dreamed about flappy paddles with fast shifts in a sporty RWD Turbo and to me the sound and feel of it cutting through gears in a steady stream is exciting, engaging, and keeps the car better balanced - I *also* like h-patterns, but I find them more engaging and fun in a nice hoonable peaky NA thing.  Type-R Integra/old school NA rotary, things that are raw and need all the rpm where picking the gear and getting it sky high is part of the engagement of the whole thing despite the fact that they probably need closer ratios and faster shifts even more than a 3l turbo thing haha
    • If I wasn't allowed or really had the desire to visit China it would probably fit in my carry on, but I have no desire, Japan would be nice during Cherry Blossom time though I might need to chat to Jackie about that, that should actually be an easy conversation though as she is currently talking about another cruise, cruise ship to Japan, a week in Japan to see the sights, then cruise home I may even be able to find those OEM NC Recaro seats over there that I cannot find here 馃
    • What do you mean?  In between the two I shared?  They're the same boost   This will be insane.   A mate has a GTSt with a 9:1 RB30/25 with Tomei 256 cams and a Borg S362SX-E that is already a beast from the basement but has a stock 5 speed and will probably get a ZF8 one day.  After the G35 900 RB26 setup I'd be lying if the topic of "Wtf would a divided G35 be like on this thing?" idea hadn't come up - you'd definitely want a wide boost control range setup with it, as even with the less responsive and potent S361 we're having to ramp boost in from very low levels in the early gears.
    • ZF8 is faster, wider ratio spread, better in every way. I do not dispute this. But I have brain damage and I want the feeling of shifting gears. To me the extra work is fun, but I daily an automatic and in the US like 90+% of cars are automatic so a manual transmission is an "exotic" experience. If I want an automatic I've driven an F80 M3 with DCT more than a few times and it's incredibly capable but it's emotionally vacant to me.
