I can vouch for the Greddy. On my previous setup I had one holding boost dead-straight for my HKS GTRS @ 20 psi. Can't remember when full boost was achieved, but it was scary responsive.. Boost would fluctuate between 19.8 - 20.7 psi when on full song. (According to boost gauge)
is 6k rpm scary responsive?
Don't rule out timing, the front of the exhaust cam can get chewed out and timing will move 10-15 degrees.. Tends to be less consistent though, will go like a shot one day and a bucket of crap the next.
Don, I think I have about 10mm now...the outer end of the actuator just touched the boss that the flapper shaft/spindle passes thru. You'll see what I mean when you check yours ;)
Checked mine and the outer end of the act sits just before the middle of the pin giving a measurement of hole center on the act to center of the pin about 7mm.
So basically with 9psi acts with less preload, we have about the same response......EBC time!!
And these turbos were proven time and time again, and as a matter of fact seen some really shitty response times for -7s as well on paper too, so its just a matter to tweaking to get them up to scratch so dont worry
There appears to be different understandings of response here....
1. The initial time it takes the turbos to spool up from idle speed during take off, and,
2. The time / delay for max boost to be achieved when you're in the turbo's working rpm band, above say 4000 etc. Eg, when you're on the track, holding 4500 around a corner and then power back up for the exit.....example 2.....you're at 4.5k, you put flat down, how long does it take to make full boost = level of responsiveness.
What we "should" be talking about in this thread is No.1....how long it takes for the turbo to get everything going hard from idle rpm. I guess it shouldn't reeeeealy be called "response" just by itself...maybe initial spool up time would be a better way of putting it :P :P
And yes, big singles can be very "responsive" up top when there're plenty of fumes going round....but I don't think you can beat the responsiveness of small twins or the stockers. When you're up it they on max in a split second - awesome on the windy roads ;)
Haha I see...yes, I think we're going to go down that path ;) I'm not gonna wind on any more pre-load for now....I need to see where this thing boosts to now without bleeding anything off (bleed valve is closed, may as well take it out). I reckon the 10mm on mine will make it boost to exactly 18 pounds or so - if it goes over, I'll have to wind some preload off :no: ....ultimately I'll have to maybe wind some off again anyway so EBC can do some controlling up there as per XKLABA's recommendations.
My 9's love the twisties. When are you getting the final tune and stuff?
ASAP mate. Right now I've been ganny-ing around with front prop shaft removed because tuning mob killed the front diff (somehow). Hope to have it in soon and then it's off for a tune once more
...also, there's the EBC....wondering if I should just putter around some more and get that as well before tuning
Yes, I would think its a good idea to let the tunner play around with it and get it all set up.
Haha I reckon anything would look good on the graph right now....they tried to tune it with the wastegates flapping in the wind - dumbasses! I mean hell, what tuner does that? "Hmmm....turbos are laggy....lets not check for mechanical issues and crank up the boost instead" GRRRRRRRR!!!! :domokun:
Right now they'd have a graph that would similar to a GT30 except a bit fatter down low...just need to have the whole show shifted forwards by another 500rpm and then I'll be a happy chappy!
So what are your plans Don? Do you have any graphs? Mine was so pathetic that I didn't take a copy....it's flat and gay and would just remind me of when I spent all that money for nothing :P
Am quite motivated now...just came back from a drive that had a highway stretch in it where I loaded them up a bit in 3rd up a hill.....expected just the normal low boost but they instead ramped up to what would have been (I backed off) around 16psi at 4000 ;) Can't wait to get it tuned so that she'll ramp up like that in the lower gears too!
tommis85: with your foot pump hooked up what pressure did the wastegate start to crack open? how much preload have u dialed in (1 full turn is equivalent to 0.8 mm) and as a result what is your peak boost.
Cheers
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
