I can vouch for the Greddy. On my previous setup I had one holding boost dead-straight for my HKS GTRS @ 20 psi. Can't remember when full boost was achieved, but it was scary responsive.. Boost would fluctuate between 19.8 - 20.7 psi when on full song. (According to boost gauge)
is 6k rpm scary responsive?
Don't rule out timing, the front of the exhaust cam can get chewed out and timing will move 10-15 degrees.. Tends to be less consistent though, will go like a shot one day and a bucket of crap the next.
Don, I think I have about 10mm now...the outer end of the actuator just touched the boss that the flapper shaft/spindle passes thru. You'll see what I mean when you check yours ;)
Checked mine and the outer end of the act sits just before the middle of the pin giving a measurement of hole center on the act to center of the pin about 7mm.
So basically with 9psi acts with less preload, we have about the same response......EBC time!!
And these turbos were proven time and time again, and as a matter of fact seen some really shitty response times for -7s as well on paper too, so its just a matter to tweaking to get them up to scratch so dont worry
There appears to be different understandings of response here....
1. The initial time it takes the turbos to spool up from idle speed during take off, and,
2. The time / delay for max boost to be achieved when you're in the turbo's working rpm band, above say 4000 etc. Eg, when you're on the track, holding 4500 around a corner and then power back up for the exit.....example 2.....you're at 4.5k, you put flat down, how long does it take to make full boost = level of responsiveness.
What we "should" be talking about in this thread is No.1....how long it takes for the turbo to get everything going hard from idle rpm. I guess it shouldn't reeeeealy be called "response" just by itself...maybe initial spool up time would be a better way of putting it :P :P
And yes, big singles can be very "responsive" up top when there're plenty of fumes going round....but I don't think you can beat the responsiveness of small twins or the stockers. When you're up it they on max in a split second - awesome on the windy roads ;)
Haha I see...yes, I think we're going to go down that path ;) I'm not gonna wind on any more pre-load for now....I need to see where this thing boosts to now without bleeding anything off (bleed valve is closed, may as well take it out). I reckon the 10mm on mine will make it boost to exactly 18 pounds or so - if it goes over, I'll have to wind some preload off :no: ....ultimately I'll have to maybe wind some off again anyway so EBC can do some controlling up there as per XKLABA's recommendations.
My 9's love the twisties. When are you getting the final tune and stuff?
ASAP mate. Right now I've been ganny-ing around with front prop shaft removed because tuning mob killed the front diff (somehow). Hope to have it in soon and then it's off for a tune once more
...also, there's the EBC....wondering if I should just putter around some more and get that as well before tuning
Yes, I would think its a good idea to let the tunner play around with it and get it all set up.
Haha I reckon anything would look good on the graph right now....they tried to tune it with the wastegates flapping in the wind - dumbasses! I mean hell, what tuner does that? "Hmmm....turbos are laggy....lets not check for mechanical issues and crank up the boost instead" GRRRRRRRR!!!! :domokun:
Right now they'd have a graph that would similar to a GT30 except a bit fatter down low...just need to have the whole show shifted forwards by another 500rpm and then I'll be a happy chappy!
So what are your plans Don? Do you have any graphs? Mine was so pathetic that I didn't take a copy....it's flat and gay and would just remind me of when I spent all that money for nothing :P
Am quite motivated now...just came back from a drive that had a highway stretch in it where I loaded them up a bit in 3rd up a hill.....expected just the normal low boost but they instead ramped up to what would have been (I backed off) around 16psi at 4000 ;) Can't wait to get it tuned so that she'll ramp up like that in the lower gears too!
tommis85: with your foot pump hooked up what pressure did the wastegate start to crack open? how much preload have u dialed in (1 full turn is equivalent to 0.8 mm) and as a result what is your peak boost.
Cheers
    • I don't know that machine specifically, but I'd personally go for something with a little more kick than 130amp. Around up to 180 would be good. At the 6mm range, you're really pushing the machine hard and don't have a long period you can run for with out needing to give it a rest. Lots of MIG machines come with a regulator and hose. A lot will come with a starter roll of wire too, but it isn't too expensive to buy. I'd recommend NOT buying a massive roll too, as you don't want it sitting around FOREVER in the machine between uses and potentially going to shit. For thin sheet metal, get a roll of 0.6mm if you're doing over 3mm and above, switch over to 0.8mm wire. Even by 2mm you'd probably really want to switch. As for gas battle, it's all swap and go style now. You'll pay a bottle deposit, and then X amount to swap for a full one. I think it's like $200 or $300 for a D Size bottle upfront as "deposit", and like $110 to $150 per swap. My D size CO2/argon bottle lasts a fair bit of welding on the MIG. And I run an E size bottle on the TIG. For DIY MIG, stick with a D size bottle. If you really start to get into a LOT of welding and doing it really regularly, then upgrade. If you're like most DIY car guys, one D bottle will last you 2 or 3 years easily. I think I've been on my current bottle about 5 years. It is starting to get low, but I've been smashing it a lot more the last 6 months.
    • SR20s came with cars like the Bluebird and Primera, but the RB20 never came. The ones in Turkey were either brought in specially or from abroad. That's why RBs aren't as common as SRs. And if a part breaks or I need to replace it when doing maintenance, it's harder to find parts for RBs.
    • I would suggest equally difficult to find, perhaps edging to the SR. Turkey has almost exclusively Euro market cars, some Korean, few Japanese other than pedestrian shite. I guess they're probably losing the fight against Chinese shit like we are now too. I would vote for a BMW V8, found in a 540i in a wrecking yard somewhere in Deutschland (or possibly Albania).
    • A CigWeld EasyWeld 130 can be had from ebay for $360 delivered. Good for 0.6 to 6mm, which would be fine for my requirements. I guess that on top of that you would need to buy a regulator, hoses and wire. I already have gloves and an auto-darkening mask. How is the gas bottle charged? Do you rent it then pay for top ups?
    • RB20 being an option from factory would mean no custom parts or fabrication required, just have to collect the right bits. Probably would be the easiest option I reckon for a motor swap. How common are SR20s vs RBs in Turkey?
