hi everyone
i have a r33 wth a rb25-30.
i have a rb20ecu with a nis tune chip. has anyone got there rb25-30 running with a rb20 ecu?
i have upgraded turbo, pistons, injectors, fuel pump, q45 afm, front mount intercooler and full turbo back exhaust.
my mechaic has told me this ecu cant be tuned so we are trying the standard computer next. he has told me to get a apexi power fc if he cant get it to run. because its running too rich.
i have contacted toshi off the forums and he said he can tune the rb20 computer to suit the engine.
has any one had this experiance before??
any help will be much apreciated
thanks
Your mechanic sounds like a bit of a numpty....
I ran my old 25/30 using the standard rb20 loom, sensors and ecu with a nistune. Ran up around 330rwkw fairly easily with the t67.
Just make sure you have the install all sorted out, then take it for a tune. The car wont really run unless it's been calibrated for bigger injectors, bigger afm etc.
Cheers
J.
He told me he can't tune the rb20 computer because I think he dosnt no how. He told me the engine is running too rich because of the bigger injectors.
Toshi said he can come tune it for me on the dyno.
My mechanic said not to drive it aswell because it's running to rich.
I'm running a rb25 loom in mine
It will be beneficial to activate the vct too... I used an msd rpm window switch to activate the vct solenoid, only a couple hundred bucks all up. get the car towed to the dyno with a fresh set of plugs, fresh oil change- filter etc. It's not going to run untill it's tuned for the larger injectors and larger afm.
Another thing to look at before you hit the dyno is the power feed to the coil pack loom. I'd run a larger positive wire to the loom through a 30/40 amp relay. Clean your coil pack boots, run a larger earth cable from the earth point at the ign pack/head to the chassis and run a .8 gap (I've always used bpr7es ngk plugs). This will give your ign system the best chance of holding high boost/combustion pressures.
Cheers
Justin
Cheers
Justin
can i ask where you got your MSD window switch from? are they easy to wire in and setup?
I got mine from JEGS from memory. If you can wire up an aftermarket headunit, you can wire this in. Just remember the vct solinoid is a negative switch.
You can buy the plug for the vct solinoid from any automotive electrical supplier or fuel injection place.
Cheers
Justin
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
