Ok, so i needed a new shim kit for my r33. Ive got the 4 pot calipers on the front, searched for a part number, 41080-21U25 is apparently the one i need.
This, according to quite a few people, is 41080-21U25:
So i went to my nissan store, forked over a large amount of cash for that part number. Except when i got it, it looked different.
I scoured the internet again, rechecked the part number, and its definitly the one from what i can tell. It says that number on the packet I got.
Is it possible nissan can stuff it up? It came in one pack.
Id just like some confirmation. Any help would be appreicated!
Edited by Nights
https://www.sau.com.au/forums/topic/403204-front-brake-shim-kits/
It was $170 off the top of my head.
Oh really? Whats I find very weird though is that the outer shim (the silver part) doesn't cover the whole piston. It gets about half of it to 3/4.
The ones in the other pic i posted first look like the correct shape, they would cover both pistons completely.
The kit in the first post looks the same as the R32 GTR (sumitomo calipers) and IIRC the 33 gtst calipers use the same pad. The shims match the profile of the pad backing plate. So what you got doesnt looks right - but i checked the part in FAST and it came back with the same part number....weird.
Is this what your looking for? http://www.frsport.c...re_p_12970.html
Yeah i saw these originally, and they look like the exploded view of the r33 brake, but yeah, it said 300zx so i thought id be safe and go through nissan.
Yeah doesnt quite look right to me either, from a design standpoint im struggling to see why only half of the pistons are covered. Yeah its definitely the part number, although its weird cos on the exploded view they definitely match the pad backing plate. Dont look like the ones i got.
When I took off my shims, the silver ones only covered about 75% of my black metal ones =S
This is off a stock r33 gtst. Here is a pic
Yeah? Maybe it is correct then. Just seems a little weird it only covers half the calipers, not to mention its not even even, it covers different amounts of both pistons :S
This is confusing.
Edited by Nights
Mine had diagonally cut silver pieces too (R33 GTS-t brakes), apparently this plate profile helps with vibrations somehow, I've seen exactly same thing done to STI and some euro cars' backplates, so your kit is the correct one
  • 11 months later...
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
