R32 Gts4 Stolen From Chirnside Park. Last Seen In Preston. Please Keep An Eye Out For Car Or Parts
Russman
 Share
Hi all.
My mate got his GTS4 stolen yesterday 22nd June from Chirnside park shopping centre.
Was last seen in preston going 150kph and cops did not pursue because was going too fast.
If you see any cheap parts and think it may be related to this car please contact me via PM and I'll pass on to owner and he'll pass on to cops.
Some parts to look out for:
Blitz return flow front mount. shiny.
Black R33 GTR rims with rash and Yokohama 225/45/17.
HKS Coilovers.
mis-matched front bumper colour.
small dint right rear quarter.
Wingless boot lid
SAFC Neo
Big skyline sticker on back window.
Thanks
Russ
  • 2 months later...
Forgot about this thread. The car was found in a very bad state. The idiot rang a tow truck to pick it up from his house! The tow truck driver ran the numbers and called police. It was found in northcote. Not sure what will happen to the thief.
Unfortunately the only thing to do is wreck what is left... At least he got it back. Better than nothing.
by bad state... you mean cracked bumpers, dented panels etc? or mechanically ruined?
Lots gone
Bar, cooler, lights, air box, koyo rad, bonnet, R32 GTR seats, scratched every panel etc...
 Share
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
    • DCS, war thunder, IL2 - mostly flight sim games.
