I was watching the drifting going on at Eastern creek last night , and i saw a r33 skyline non turbo drifting he did have alot of trouble with his single spinner, but towards the end he got alot better, he also stock suspension by the looks of it.
I was thinking about throwing on some coil overs and a turbo r33 lsd heard the gear ratios were the same.
Anyone ever installed the GTST LSD on a n/a? does it handle alot better?
https://www.sau.com.au/forums/topic/403218-installing-lsd-on-na-r33/
The ratios are different, the GTST diff has a longer ratio.
Also the stock diff if a viscous diff which pretty much all of them are worn out and will just single peg all day long. you could shim it to lock it a bit more. there is a thread in the DIY section about it people have had good results
What car are you planning to do this with?
If you have a 33 ratios are the same for NA or turbo but it depends on if you get an auto or manual diff.
If you're planning it for a 31 which is the only car you have listed then it's a lot more involved.
If Jap Spec IRS They run an R200 Longnose diff which isn't just a simple swap. You'd probably need to do the whole subframe etc with custom mounts, custom tailshaft etc.
If Aus spec live axle you will need to do the same as the Aus specs run a Borg Warner diff which is entirely different. Kaaz offer an LSD centre for these diffs or you could use a cone type LSD out of a Sillhouette though I don't think they are particularly strong.
Haha i just edited that part of my profile as you were posting, Yeah i have a r33 non turbo. i think the auto diffs have a 4.3 something ratio, which is higher then the manual ones.
Yep autos are 4:3, manuals 4:1
If your car already has an LSD shimming it is your cheapest option. If it's a single spinner then you'll need to source an LSD centre and probably shim it.
If you post your VIN in the VINS you want fasted thread in General automotive discussion it'll tell you if your car is a GTS25/S which will have an LSD or just a normal natro which won't.
  • 1 month later...
  • 3 months later...
hey everyone. rather than starting my own thread and asking the same thing. i have a 1995 r33 gts25 and im wondering if i have an lsd... im going to jack the car up (rear) in a minute and give it a rev but is this definate... cause what if its warn and only one spins? how much does shimming a diff cost?
I also have a R33 S1 and well looks like there are a few of us that are in the same boat. Now which do you guys think is best? shim or just solid weld the diff? Why do you prefer the weld or the shim? and what prices would one expect to pay to get the diff welded or shimed? I do not know much about a diff except how it operates. Any advice would help
Shimming costs more and retains some form of LSD depending how "tight" you go. Welding it is as simple as well welding the spider gears lol.
Get a mate that's handy with a welder and give him a bottle of spirits (as payment), down side is its illegal and very easy to see/hear on the street.
    • Everything I found online said never use it because it'll dramatically reduce belt lifespan.  No, but I have seen excessive v-belt tension cause the audible bearing noise from excessive radial load in things like alternators. So don't overdo it. Ideally you set it to manufacturer spec using a proper belt tension guage. I tried the "clicker" type gauges but those cheap things are trash. They read way too low even when you're careful.
    • This is kind of where I've ended up for the most part. It's easier for me, easier for shops that don't have to deal with my weird criteria/picky standards, etc.
    • Will do. Suprised if it's not the starter motor considering it's 30 years old. Will get a volt meter though. Battery is close to new.   Cheers for your help, always appreciated.
    • This almost never happens these days. No. Clean your battery terminals and make sure they are tight. Use sandpaper on a dowel if you have to, to get oxidation off the inside of the terminals, particularly on the -ve. Check the earth cable from battery post to chassis ground and engine ground. Make sure the contact surfaces are clean - including the threads on the bolts that anchor them - because that's where a lot of the contact occurs. Wire wheel on a drill is a good thing for this. Make sure the crimps on those cables are all sound. Assuming none of that causes an improvement: Check the battery voltage after it has been resting for a while. If it's at the lower end of the range, put it on charge for a while, then see if it will crank better.
    • I just checked my belt, it wasn't super loose but I could bend it past 90 degrees a small amount so I tightened it up and for the first time ever my car didn't crank first time, had to crank it again lol. Don't know if that was because I tightened the belt or if it's my starter motor going out (been having slow starts for some time). Coulda also been when I was recording I didn't crank the key properly and it didn't save the recording lol.   Is that a thing if you overtighten a belt it struggles to start?
