FOR SALE KE70 1984
Hey guy's selling my ke70 due to need money to go oversea's.
The body isnt in the best condition has a few dints here and there and rear quarters are abit rusty.usaul spots
The car will come with EVERYTHING im gonna write just minus engine and gearbox,all you need for this car is a sr20 and manual gearbox and everything will drop in and run and drive
Whole s13 front end(k-frame,hubs,knuckles,lcas etc)
tein monoflex coilovers(2way height,damper,camber)
1 piece tailshaft
r31 diff with 4.1 ratio
3inch cat back exhuast
hydraulic handbreak
4 point half cage(meets the new schedule j requirments)
s14 brake booster and master cylnder
rear has kyb short shocks
6kg rear springs
s14 steering column
power steering
bride zeta II
batery in boot
switch board
15x7.5 0 offset southern way meshies on front
There would be a few things i forgot i will add them when i remember
as i said guys this car just needs engine and gearbox and its ready to slide.
SMS only 0449935304 for inquries and pictures
$2000 or $1500 and suply your own front wheels
https://www.sau.com.au/forums/topic/403221-for-saleke70-sr20/
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
