FOR SALE KE70 1984
Hey guy's selling my ke70 due to need money to go oversea's.
The body isnt in the best condition has a few dints here and there and rear quarters are abit rusty.usaul spots
The car will come with EVERYTHING im gonna write just minus engine and gearbox,all you need for this car is a sr20 and manual gearbox and everything will drop in and run and drive
Whole s13 front end(k-frame,hubs,knuckles,lcas etc)
tein monoflex coilovers(2way height,damper,camber)
1 piece tailshaft
r31 diff with 4.1 ratio
3inch cat back exhuast
hydraulic handbreak
4 point half cage(meets the new schedule j requirments)
s14 brake booster and master cylnder
rear has kyb short shocks
6kg rear springs
s14 steering column
power steering
bride zeta II
batery in boot
switch board
15x7.5 0 offset southern way meshies on front
There would be a few things i forgot i will add them when i remember
as i said guys this car just needs engine and gearbox and its ready to slide.
SMS only 0449935304 for inquries and pictures
$2000 or $1500 and suply your own front wheels
https://www.sau.com.au/forums/topic/403221-for-saleke70-sr20/
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
