Hi Guys,
Appologies if this is in the wrong section. My brother in law bought this car
http://www.skylinesa...-skyline-gts-t/
and has now got a wierd problem with it. Basically the car won't rev over 2200rpm(ish) under load and 3500rpm(ish) when sitting still with clutch in. There is also a random hesitation that kicks in at all rpms when it likes.He has basically given up on it and asked me to take a look.
So far I've fixed a loose AFM plug and cleaned it, swapped ignitors, cleaned just about every connector in the engine bay, moved the JECS injector resitor pack away from the turbo manifold (as it was getting bloody hot), re-earthed most of the engine bay. Earthed his bosch fuel pump to the chasis, checked the ECU in diag mode got the "55 all fine", checked for boost leaks (found two hose clamps loose) and scraped most of the skin off my hands with no improvement :(
I've spent hours googling the crap out of this and am coming up blank. help is appreciated guys.
https://www.sau.com.au/forums/topic/403223-rb20det-power-loss/
Check timing with a timing light.
The link mentions a 2nd hand CAS, maybe that CAS was borked too.
Does the engine run fine cold, then get issues once warm/hot?
Compression results?
Is the ECU firmly plugged in?
What does the TPS read at idle, and WOT?
Spent a fair bit of time with this car on the weekend. I disconnected the AFM, TPS, temp sensors and a few others individually to see what differences it would make, the only one that put out an error code on the ECU was the AFM when it was disconnected.
Can seems to get worse once it is warmed up, wondering if the the ecu when changing from the cold start to the running map is picking up something and going into limp home mode.
Anyone live in the blacktown area want to lend me an AFM/ecu to test with for about 30min for a case of beer or bottle of jack?
Limp can also be the tps as I found out. Can you measure the voltage output or get a reader onto it?
Did you cut open the AFM and solder the pins inside?
I'm always willing to help for Jack, shame you are so far away. :(
If it were my car, id be very concerned with the following:
JUST RECENTLY INSTALLED JJR PERFORMANCE COIL PACKS
SECOND HAND CAM ANGLE SENSOR , AIR FLOW METER AND IGNITOR FROM SUMO JAP SPARES
all of the above sounds dodgy to me, everything is either shitty or second hand, so even if it did run well , how long would it stay that way?
JJR coilpacks sound cheap and nasty..
Jjr coilpacks are the justjap ones. For the S2 they are prone to failure and Justjap happilyrefunded me for mine having the receipt and me bring the buyer. The car still revved up just on 5 cylinders. Try a different ecu if you have already tried a new.afm and coilpacks.
Got a multimeter onto the TPS, one of the plugs gives a value from 0.1-1.0 volts depending on throttle position, other plug goes from 0.1-0.3 then to infinite value, does anyone know if this is normal, could it be WOT value?
  • 4 weeks later...
I had this exact problem. I had a contaminant in the fuel which made my Bosch itank pump slowly die.
Check the fuel rail pressure
CHeck the pumps mesh filter for anything. Does te pump sound noisier than normal? Is than basically silent?
  • 8 years later...
Hey man, I'm having basically the same exact problem and given this was back in 2012 lol idk if you would so happen to rememeber what the problem(s) were and how you fixed them ? I've reached a dead end and basically checked and done everything that I can think of and then some, along with trying things from reading on here
I hope you can help !
    • I like it when the counter chick leads you out the back into the racks and says "have a grub around in here and see if you can find what you need. I'll be back in a few minutes. Just left me in front of a massive motorised shelving system and 2-3 million fasteners, so I could find a peculiar SS shoulder bolt with cap head. Gotta love country towns.
    • I used this https://osgiken.com.au/product/os-giken-os-250r-lsd-gear-oil-80w250-1-litre/   shut my nismo 1.5 pro up by heaps…. Not silent though. Gives the car character and personality. It ain’t a carolla. If you want silent, put a quaife in it.
    • It's about the same time for me from Bunnings, or the Fasteners. My big push away from takeaway food, and gluten in general keeps me away from the Bunnings Snags too! Weather up here, I've been out for two walks today in the beautiful sunshine. Had a few little drizzles, and some wind, that honestly, a tin of beans and I could compete on how harsh she blows Thankfully, being this bit inland, we're not getting anything much really. Will probably pick up a bit more when/if Cyclone Alfie decides to come ashore. A few areas in the GC though, and south into NSW are really getting smashed though! Right now, I'm just annoyed Alfie hasn't hit, as I'm not allowed to crack into the BBQ foods like the bacon and eggs until the Cyclone hits "In case we lose power"...
    • I love fastener joints, the price difference between them and joints like Bunnings or Super Cheap is amazing, and they either have exactly what you want, or they can get it to quick They have even given me some for free when I only needed a couple of specific size In saying this, I have paid premium for fasteners from Bunnings if they have the sizes I need, but only for convenience really, as my local is only 10 minutes away, the Sushi joint near them is also a consideration  How's the weather Matt? Stay safe mate
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
