Hi Guys,
Appologies if this is in the wrong section. My brother in law bought this car
http://www.skylinesa...-skyline-gts-t/
and has now got a wierd problem with it. Basically the car won't rev over 2200rpm(ish) under load and 3500rpm(ish) when sitting still with clutch in. There is also a random hesitation that kicks in at all rpms when it likes.He has basically given up on it and asked me to take a look.
So far I've fixed a loose AFM plug and cleaned it, swapped ignitors, cleaned just about every connector in the engine bay, moved the JECS injector resitor pack away from the turbo manifold (as it was getting bloody hot), re-earthed most of the engine bay. Earthed his bosch fuel pump to the chasis, checked the ECU in diag mode got the "55 all fine", checked for boost leaks (found two hose clamps loose) and scraped most of the skin off my hands with no improvement :(
I've spent hours googling the crap out of this and am coming up blank. help is appreciated guys.
https://www.sau.com.au/forums/topic/403223-rb20det-power-loss/
Check timing with a timing light.
The link mentions a 2nd hand CAS, maybe that CAS was borked too.
Does the engine run fine cold, then get issues once warm/hot?
Compression results?
Is the ECU firmly plugged in?
What does the TPS read at idle, and WOT?
Spent a fair bit of time with this car on the weekend. I disconnected the AFM, TPS, temp sensors and a few others individually to see what differences it would make, the only one that put out an error code on the ECU was the AFM when it was disconnected.
Can seems to get worse once it is warmed up, wondering if the the ecu when changing from the cold start to the running map is picking up something and going into limp home mode.
Anyone live in the blacktown area want to lend me an AFM/ecu to test with for about 30min for a case of beer or bottle of jack?
Limp can also be the tps as I found out. Can you measure the voltage output or get a reader onto it?
Did you cut open the AFM and solder the pins inside?
I'm always willing to help for Jack, shame you are so far away. :(
If it were my car, id be very concerned with the following:
JUST RECENTLY INSTALLED JJR PERFORMANCE COIL PACKS
SECOND HAND CAM ANGLE SENSOR , AIR FLOW METER AND IGNITOR FROM SUMO JAP SPARES
all of the above sounds dodgy to me, everything is either shitty or second hand, so even if it did run well , how long would it stay that way?
JJR coilpacks sound cheap and nasty..
Jjr coilpacks are the justjap ones. For the S2 they are prone to failure and Justjap happilyrefunded me for mine having the receipt and me bring the buyer. The car still revved up just on 5 cylinders. Try a different ecu if you have already tried a new.afm and coilpacks.
Got a multimeter onto the TPS, one of the plugs gives a value from 0.1-1.0 volts depending on throttle position, other plug goes from 0.1-0.3 then to infinite value, does anyone know if this is normal, could it be WOT value?
  • 4 weeks later...
I had this exact problem. I had a contaminant in the fuel which made my Bosch itank pump slowly die.
Check the fuel rail pressure
CHeck the pumps mesh filter for anything. Does te pump sound noisier than normal? Is than basically silent?
  • 8 years later...
Hey man, I'm having basically the same exact problem and given this was back in 2012 lol idk if you would so happen to rememeber what the problem(s) were and how you fixed them ? I've reached a dead end and basically checked and done everything that I can think of and then some, along with trying things from reading on here
I hope you can help !
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
