Hi Guys,
Appologies if this is in the wrong section. My brother in law bought this car
http://www.skylinesa...-skyline-gts-t/
and has now got a wierd problem with it. Basically the car won't rev over 2200rpm(ish) under load and 3500rpm(ish) when sitting still with clutch in. There is also a random hesitation that kicks in at all rpms when it likes.He has basically given up on it and asked me to take a look.
So far I've fixed a loose AFM plug and cleaned it, swapped ignitors, cleaned just about every connector in the engine bay, moved the JECS injector resitor pack away from the turbo manifold (as it was getting bloody hot), re-earthed most of the engine bay. Earthed his bosch fuel pump to the chasis, checked the ECU in diag mode got the "55 all fine", checked for boost leaks (found two hose clamps loose) and scraped most of the skin off my hands with no improvement :(
I've spent hours googling the crap out of this and am coming up blank. help is appreciated guys.
https://www.sau.com.au/forums/topic/403223-rb20det-power-loss/
Check timing with a timing light.
The link mentions a 2nd hand CAS, maybe that CAS was borked too.
Does the engine run fine cold, then get issues once warm/hot?
Compression results?
Is the ECU firmly plugged in?
What does the TPS read at idle, and WOT?
Spent a fair bit of time with this car on the weekend. I disconnected the AFM, TPS, temp sensors and a few others individually to see what differences it would make, the only one that put out an error code on the ECU was the AFM when it was disconnected.
Can seems to get worse once it is warmed up, wondering if the the ecu when changing from the cold start to the running map is picking up something and going into limp home mode.
Anyone live in the blacktown area want to lend me an AFM/ecu to test with for about 30min for a case of beer or bottle of jack?
Limp can also be the tps as I found out. Can you measure the voltage output or get a reader onto it?
Did you cut open the AFM and solder the pins inside?
I'm always willing to help for Jack, shame you are so far away. :(
If it were my car, id be very concerned with the following:
JUST RECENTLY INSTALLED JJR PERFORMANCE COIL PACKS
SECOND HAND CAM ANGLE SENSOR , AIR FLOW METER AND IGNITOR FROM SUMO JAP SPARES
all of the above sounds dodgy to me, everything is either shitty or second hand, so even if it did run well , how long would it stay that way?
JJR coilpacks sound cheap and nasty..
Jjr coilpacks are the justjap ones. For the S2 they are prone to failure and Justjap happilyrefunded me for mine having the receipt and me bring the buyer. The car still revved up just on 5 cylinders. Try a different ecu if you have already tried a new.afm and coilpacks.
Got a multimeter onto the TPS, one of the plugs gives a value from 0.1-1.0 volts depending on throttle position, other plug goes from 0.1-0.3 then to infinite value, does anyone know if this is normal, could it be WOT value?
  • 4 weeks later...
I had this exact problem. I had a contaminant in the fuel which made my Bosch itank pump slowly die.
Check the fuel rail pressure
CHeck the pumps mesh filter for anything. Does te pump sound noisier than normal? Is than basically silent?
  • 8 years later...
Hey man, I'm having basically the same exact problem and given this was back in 2012 lol idk if you would so happen to rememeber what the problem(s) were and how you fixed them ? I've reached a dead end and basically checked and done everything that I can think of and then some, along with trying things from reading on here
I hope you can help !
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 馃槕. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
