Ok I did a search but couldn't find what I wanted, am looking for where I can find fuel injector adapters in Sydney to hook up my 60lb Siemens deka injectors to the wiring loom.
So the 6 adapters have to be USCAR EV6 female to Nippondenso male. Am I correct that the R34 factory loom has the Nippondenso female connector?
Rang up Bursons got told theres 3000 diff types of connectors and they dont have it, got referred to a supposed injector specialist in Bankstown who seemed to have had too many kebabs and not a clue what I was after. Found a couple places in SA who have them but cant be fked waiting, any places you recommend in Sydney?
https://www.sau.com.au/forums/topic/403224-fuel-injector-adapters/
After a week of searching and ringing around, I found this:
http://www.sonicperformance.com.au/95242/Injector-Plug-Connector-Denso-To-US-Car-Convertor/pd.php
Most places sell the Bosch EV1 to USCAR adapter:
http://www.ebay.com.au/itm/Bosch-Ev1-Male-Uscar-Female-Injector-Plug-Adaptor-/230743957996?pt=AU_Car_Parts_Accessories&hash=item35b96961ec
Can anyone please confirm this (first link) is the way to go or should I get USCAR pigtails for my Siemens Dekas and get that soldered onto the R34 loom?
cheers R
  • 1 year later...
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
