Hi all, I have a question.
My base timing is set at 20 btdc by my tuner, and im sure it was 20 degrees before this, but I have just put on a ross balancer, and whenever i pull stuff apart I disconnect CAS so as to check everything over before re-connection and starting. Now I had a tune 1000 ish kms ago and I had Adjusted CAS previous to that to 20 degrees, he checked it and locked it into the ecu, and said it was good. However when I adjusted it, I hadnt tightened the bolts right up. 2 loose and 1 just nipped up a bit. All would be good but i may have moved it when disconnecting. So I tightened it up where it was. Check timing and its at 15 degrees, now the only variable is the balancer marks, My old one looked ok, I thought it might be rotated a little but seems fine. Now i trust the ross one is perfect.
So having retarded timing (i think) i figured no damage can happen, so i went for a drive, I only take it out every few weeks so I didnt notice any power difference. However I did a 4th gear pull right out and it had the odd cough feeling hesitation on full boost a couple of times and throughout the drive. It never has before.
So ill get to the point, is there a way to tell where it should be vs where ecu thinks it is?
Would the ross timing marks be perfect with stock balancer?
Just need some confirmation I dont want to set it at 20 and it be wrong. Im sure iv just bumped it around a tad but not sure if theres a way to make certain so I hope someone can clear this up.
Oh and I wasnt doing the 4th pull on the public road either. It was a local private air strip.
Thanks in advance
Thats what I have done, but im getting a different reading now with new balancer, im not sure if balancers are a bit different with readings or iv accidentally moved cas. Im thinking number 2
What ecu have u got! If ur base timing was 20 degrees btc then u had a tune, if u have a sftermarket ecu and the tuner has advanced the timing via the ecu to make more power then there is quite a chance that it wont be 20 degrees' all timing marks on any balancer should b as good if not better thsn standard.
Bedt bet would go to ur tuner and get a touch up tune just to b shure!
Im no expert though but thats what id do!
A tuner would rarely adjust the timing around idle unless there was a timing problem. There is no gain from advancing timing in these cells
Adjust your base timing back to 20 degrees if this was where it was set
I would go back no worries but its a 600+ km drive to do so.
If everyones confident the marks will be spot on I will just set it back to 20 degrees. Just sucks I didn't tighten it up properly!
I will contact tuner tomorrow and check but im dead sure it was 20 on balancer.
Just needed some confirmation thanks
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
