firsty the car is making 236rwkw with an rb25det series 2, garrett 3071, power fc, 555cc injectors, 19psi etc and began making a misfire when i hit about 4000rpm on full throttle. i could lightly use the go pedal and creep up on boost but the misfire seemed only when throttle was mashed to the floor.
was in need of service so while doing oil etc decided to change plugs. they looked fine and even through out 1-6 when i pulled them out. i made the mistake of putting back in platinums with a 1.1 gap (heat range 5) and the problem became worse. like really bad pretty much had to drive around off boost. anything above say 50% thorrle gave a misfire and a continuous one at that. i thought it might be coil packs but read the forums and found out that the higher power output from standard the gap of the spark plug should decrease. i was unaware of this.
changed the plugs back to the standard $5 plug and gapped them at the 0.8 which seems the norm for most people on here. guess what.........problem has been pretty much resolved. it slightly misses once at about 4000rpm but other than that i can make full use of the power the car has.
any other ideas about what could be causing this slight misfire still. not that its a bad miss(compared to the old plugs and the platinums) more like a clearing of the throat quickly, but it shouldnt be there as it never was when i got the car back after having the upgrades done around 14months ago(bout 12000km's). i should have tested the resistance on the packs but it became dark, might do tomorrow if i have the time.
any ideas
mick
https://www.sau.com.au/forums/topic/403237-spark-plugs-and-gaps/
1-standard coilpacks should be replaced, there old
2-whats going on with that power output? thats a low figure for that boost isnt it??? i was recently speaking to MTQ and they were talking about a guy that made 300kw with a gt3071, but surely atleast 260kw's is expected.
Edited by SliverS2
+1
Also do as blind_elk stated, get at least a heat range 6 plug with a 0.9mm gap. Get it back on the dyno and get the tuner to sort out the tune because unless you have noticable intake or exhaust restrictions you should be making around 260kw with that setup.
I still believe one coilpack could be still out, if u have a friend with the same car, swap the coils over and see if it solves the missfire, i had exactly the same prob, bought new coilpacks, prob gone completely
Because you are making more power than standard, you might like to try a heat range 6 plug, gapped down a bit, say 0.9 .
the fella at auto one suggested these also.....think he said they were in the platinum range
+1
he did tell me if i wanted a power figure he could get me the 260ish. he said it was tuned really safe and also by lunchtime it was 40degrees(i was there watching the tuning on the dyno). i dont think i ever put the graph on the critique my tune section, so maybe i should, or maybe post it here if your keen to check it out.
i was a little dissapointed at first but glad it made that(236) as the old engine had done 340000km's so it was a massive improvement for me. but now i am thinking of going for more power so i will need to contact him, however i dont know where he has moved to. Not sure if i should say who tuned it now, but i was extremely happy using him to do all the work for me and he is pretty well known amongst silvia enthusiats. i would recommend him to anyone as i had no nonsense with him doing the work for me, we sat down at the start of it all, what i wanted to do with the car etc, then questions bout parts etc. he came back to me with some options and rough extimate and was very helpful with all my questions. didnt exceed my budget by too much which is always good.
ill prob be checking them out tomorrow and testing the resitance to see if they are still fine, if they arent well ill buy the splitfires. looking to get a new loom while im at it also
Resistance wont tell u a thing.
U can try gapping the spark plugs down to .6mm or
Get some splitfires
Get some splitfires
so even if the coilpack is rooted the value will still read in the 0.6 - 0.9 range??? im waiting for my mate to buy some splitfires which isnt too far off, maybe we can get a discount if we buy two sets, dont mind spending cash but if i can save a little i will.
There's more the the coilpack than the primary winding. So, if the primary winding is NOT 0.6 - 0.9, you KNOW its stuffed. If it IS 0.6 - 0.9 it MAY or MAY NOT be stuffed. Or to say it another way - that check can only confirm that its broken, not that its good.
If you can see any arcing marks, use the coilpack fix from the DIY. It addresses another issue that can go wrong with them, that is, that the insulation has failed.
Gap the plugs down to .6, if the miss goes away then be happy. If it doesn't make any difference then something else is up and your coilpacks are probably no good. Much cheaper (free if you have the tools) to simply gap the plugs down before you go changing coilpacks or anything else.
  • 2 months later...
How much of a difference does the heat range make, im running 22psi and its breaking down up top, im running 6's at .8 any idea if 7's at .8 would fix it or should i go straight to 6's or 7's at .6?
If you're getting down to 0.6 gap its time to look at your coils. I have new OEM coils running BCPR7ES at 0.9 20psi (280kw) going up to 25psi soon - no missing.
That thought has crossed my mind, i have fairly new yellow jackets but maybe its time to get some splitfires.
i ended up getting new oem coilpacks from adam on here (rbceffy25) and installed them two days ago. my car is now running like the day i got it back from the conversion, upgrade and tuning work. its running sweet as now, all the power is back. my old coilpacks had scorch marks so i guess three of them were arcing to the bracket that holds them in place.
now that this has been sorted, could i put back in the platinums with a 1.1 gap (heat range 5) and expect it all to be good. i was thinking that with the new coilpacks the gap could be a little larger than the 0.8 that i have the coppers adjusted to.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Right, here's a video of the basic operation at least.  This is what you can expect day to day when you turn the car on and it boots from standby.  The only thing from a media point of view I haven't gotten working is for it to autoplay plexamp when it turns on from standby (it works from cold boot) but that's more of a plexamp problem as it will autoplay other music players.  Also attached is my one stray cable.  It's part of the screen's wiring adapters but there's just nowhere for it to go in my car.  I've just now done a bit of research and found a matching port on a 2010-2014 head unit with BOSE.  Mine has no BOSE so that's that case pretty much closed I think.  Plugging in the Infiniti AC panel basically did nothing for me, so that's a dead end as well.  Next port of call is to mess with this CANBUS module and see what I can find from it.  I found this resource containing the DBC files for a 2010+ G37 : https://github.com/icecube45/Dash_InfinitiG37/blob/master/InfinitiG37.dbc I'll now have something to go from when I try to extract my CANBUS data so I can see if the HVAC Mode, Fan Speed, Temperature, etc. match and also the gear shifter position.  It's a pretty big assumption that it's just mismatched CAN signals but considering all the devices in the CAN network are talking to each other (AC can be fully adjusted just with no info on screen) it might be a safe one.  I will report back WhatsApp Video 2025-02-26 at 12.49.10.mp4
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
