Hey guys i have my sbach plane for sale never been flown
i have upgrade everything on this plane except the motor
specs are as followed...
The Sbach 342 has taken the aerobatic world by storm since its introduction, its combination of stunning good looks and extreme aerobatic capability has made it a firm favourite with RC pilots the world over, now finally a Plug and Play version is available for those who want to get into the air quickly and with the minimum of fuss.
As you would expect, the Sbach is made from tough EPO foam, it is a really quick and simple build that requires no glue, the tail plane simply bolts on and the 2pc wings are a plug in set up, also ideal for transportation. The servos are pre-installed, the elevator/rudder servos being standard size with plenty of torque for aggressive 3D maneuvers. Also pre-installed is the powerful brushless motor and ESC, for maximum performance and efficiency, a 2 blade prop is supplied.
This fantastic looking Sbach 342 offers both the 3D pilot and sport pilot a very capable model with tons of performance and a whole load of presence, the large control surfaces are perfect for just about any maneuver you care to throw at it. This superb Sbach 342 will keep you grinning from ear to ear, just make sure you have plenty of Lipolys to hand, prop hanging the Sbach is addictive!
Features:
Tough EPO Foam construction
Proper hinged control surfaces
Plug in wings for ease of transport
2 Blade prop for maximum thrust on 4s Lipoly
Standard size elevator & rudder servos
Pre-applied waterslide decals
Simple and fast assembly, full instruction book supplied
Seperate canopy for those wanting to install pilot figure
All control surface throws and expo rates given
Specs:
Wingspan: 1400mm
Length: 1400mm
Flying Weight: 2300g
Motor: 4250 Brushless Outrunner 800kv
ESC:Turnigy dlux 100A SBEC Brushless Speed Controller w/Data Logging
SERVOS: 2X GWS Park HPX Servo 19g/.05sec/3.6kg
2X Corona Digital Servo 2.2kg / 12.5g / .11sec
all push rod ends and arms have been also upgraded to ball joints!
Requires:
Your Own 4 Channel TX/RX
3300mAh 4s Lipoly Battery
all this has cost me alot of money so grab yourself a bargain
for further questions msg me on 0437581414
due to size pick up only from cranbourne nth
$300onopost-16324-0-40510900-1340517350_thumb.jpg post-16324-0-70283300-1340517364_thumb.jpg post-16324-0-30157500-1340517365_thumb.jpg post-16324-0-94099500-1340517365_thumb.jpg
https://www.sau.com.au/forums/topic/403284-rc-plane-sbach-342-3d/
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
