Hi i'v owned this bike for 4 years and its been fun but time to let it go.
Very fast reliable bike
42500km
spec list
Make ModelYamaha FZR 1000 EXUP
Year1992
Engine
Liquid cooled, four stroke, 35° forward inclined transverse four cylinder, DOHC, 5 valves per cylinder.
Capacity1002Bore x Stroke75.5 x 56 mmCompression Ratio12.0:1
Induction4x 38mm Mikuni BDST
Ignition / StartingDigital / electric
Max Power 145 hp 105.7 kW @ 10000 rpm (rear tyre 131.7 hp @ 10500 rpm)
Max Torque10.9 kg-m 107 Nm @ 8500 rpm
Transmission / Drive5 Speed / chainFrameDdiamond Deltabox
Front Suspension43mm Telehydraulic for adjustable preload, 120mm wheel travel.
Rear SuspensionGas/oil single shock, rising rate adjustable preload and damping. 130mm wheel travel.
Front Brakes2x 320mm discs 4 piston calipers
Rear BrakesSingle 267mm disc 1 piston caliper
Front Tyre130/60 VR17
Rear Tyre170/60 VR17
Dry-Weight / Wet-Weight209 kg / 236 kg
Fuel Capacity 19 Litres
Consumption average16.3 km/litres
Braking 60 - 0 / 100 - 013.1 m / 37.0m
Standing ¼ Mile 10.1 sec / 216.8 km/h
Top Speed273.4 km/h
1992
FZR 1000 RU exup
Got a few mods
steering dampener
electronic speedo
flush indicators
3 way adjustable leavers
clip on's
k&n air filter
dyno jet stage 1 kit
drag pipe
New parts
front brake pads
fork seals
grips
back tyre 180/55 pilot power
front tyre diablo strada
battery
I have all the fairing parts that will b sold with the bike.
Light,screen ect
sold unreg
Any Q's just ask
willing to swap wrecked r32 33 let me know what you've got
cash both ways
Edited by Na boy
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
