I've got all this gear that won't be put to use on my new build, so it's gotta go!
1. GT3076R turbo kit
Includes
- Garret GT3076R near new less than 1000k
- Tial 38mm external wastegate near new less than 1000k
- custom made screamer pipe used for 50kms MAX
- custom made 3 inch dump pipe, wrapped in billion exhaust wrap used for 50kms MAX
- custom aeroflow turbo and waterlines used for 50kms MAX
- Hybrid performance steam pipe manifold used for 50kms MAX
-GT3076 custom oil drain piping
All is near brand new, and is essentially everything you need to have a great setup. This made 318kw on 15psi on my RB25.
not looking to seperate.
$3000
2. Power Enterprise 850cc sidefeed injectors
Near new, used on my car for 50kms max. E85 compatible.
includes a Nismo FPR, fuel rail and modified OEM injector harness.
$950
3. OEM RB25 side feed injectors in fuel rail
No use for it
$120
4. RB25 cam covers and front timing cover
no use for it
$120
5. Nismo twin plate push type clutch
made by Tilton
plenty of meat, great pedal feel. Held over 300kw without problems.
$800
6. Trust DD exhaust
back part modified so it's one piece.
includes 3 inch de-cat pipe.
$400
7, Cusco catch can
no use for it
$120
I am happy to ship at buyers expence. I am open to offers but please don't waste my time lowballing.
I am located in liverpool region, NSW.
PM me if you are interested.
Thanks,
Adam.
Generic rear arm kit:
Includes:
Rear camber arms
rear traction arms
rear toe arms
will fit R33 R34 S14 S15 C34 and maybe some others.
barely used, great condition. Bearings are like new.
$300 shipped
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=post&attach_id=391834
9. 3 inch blast pipes
Brand new, no use for them.
$180 shipped
10. 3 Inch resonator
brand new, no use for it. Same as in picture but painted silver.
$80 shipped
Includes:
Rear camber arms
rear traction arms
rear toe arms
$300 shipped
Does this eliminate hicas?
Shit, I forgot about that.
Nah I've got an S14 subframe in my R33 :(
So these will fit S14/S15 and C34 fine. R Chassis will need to ditch the toe arms (where HICAS sits).
14. KTS inner and outer tie rods
Changing my setup, adds lock and reduces bumpsteer on slammed cars.
Fits 33/34/S14/S15 etc
$220 shipped
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
