1992 Skyline hcr32 type-m
Reg til feb/9/2013, does not come with rwc
JJR split dump front pipe
Catco de-cat
Custom 3inch cat-back with Varex muffler
Blitz cs return flow intercooler
Heavy duty clutch
Bosch 040 intank fuel pump with high flow fuel filter
Locked diff
K&n pod filter (in custom shitty airbox)
D1 earthing kit
ISC n1 coilovers 10kg front, 8kg rear, 32 step damper adjust (currently set very stiff, but are fully adjustable)
Front and rear strut braces
Full hicas system removal with lock bar and Tom’s hicas canceller
Nolathane caster bushes
r33 lower control arms
GKtech extended and strengthened tie rods
GKtech rack spacers
GKtech solid steering bush (not fitted)
GKtech extended strengthened wheel studs front and rear (rears not fitted)
Autometer cobolt boost gauge
Cluster lights replaced with leds
Nismo gearknob
Momo steering wheel
Pioneer head unit
Sony xplod speakers front and rear
Dmax roof wing
Weather shields
New speedo cable and sender
New turbo to manifold gasket, turbo to dump gasket and exhaust gaskets
New cam cover gaskets
New gearbox oil
New diff oil
Only use castrol edge 10w60 engine oil
Run only on bp ultimate
Choice of Work VS-XX 17x7.5 and 17x8.5 or Lenso d1rs 17x9 all round
All standard parts ie fog lights, intercooler, hub linings, struts with springs, hicas lines pumps rack etc.etc.. will come with the car
My price is $8500 for everything. I am negotiable i.e no reg/no wheels/less parts=less price, however any offers lower than $7000 will be ignored as I am in no rush to sell.
Contact 0408 543 455
-Ev
    • Reasonably hard, although I haven't run it with the new Endless setup yet. The old brakes were F50's on 335mm rotors and the car did a 1:40.6 at Phillip Island which is a reasonable time, I'm seeing high 600s on the temperature paint. A guy I know ran the Endless fluid at WTAC without issues and he was doing 1:33's I think (Evo) with a 355/332 setup. I don't get out to the track as much as I'd like but we put the car on the hoist and spanner check every bolt and re-paint mark everything, bleed the brakes, change the fuel, check the coolant system and re-bleed blah blah blah before every event. Motorsport is expensive, RB's are expensive so a couple of hours before an event is time well spent. It's also a net time saving because if you can keep your RB from self destructing it saves you time in the long term!
    • Welcome Alice......hope you have a bit more luck from here on! What was done in the build?
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
