  • Replies 76
not that i know off??
I have bought a set of rims and they arent sitting the same as the exact same items on my old 33 GTR. I cant understand why... just need some comparisons.
And if anyone is running 18x10 +18 id love to come over and just see how they sit
Its going into a suspension place today to check it out for me, camber etc. But to the naked eye it doesnt seem to bad... i mean on my last GTR the rims sat around 3mm inside the gaurds. these sit a solid inch!
I may have found the problem. Has anyone ever heard of this. The place measured the offset and said it's around + mid to late 30s and not +18, even tho they are clearly marked +18?? This would explain a lot but I've never heard of this happening before? ? ?
Does anyone else have XD9s in this size?
Maybe they have had the mounting face machined down at some stage.
Make sure that they measured them to the tyre bead not the edge of the rim, 12 mm isn't much difference.
Yer I just got home and measured it myself. The rims right, they were wrong.
Back to square one....
Does anyone in Adelaide have a stock 33 Gtr that would allow me to test these rims front and back on?
Or better yet have a set of 18x10 + 18s on a 33 Gtr?
Really need help guys...
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
