Fs [Syd]: Turbosmart Dual Stage Boost Controller, Auto Meter Cobalt Boost Gauge, Hr Racing Pegasus 19X8.5" & 19X9.5" Rims & Tyres
Hello,
Just some stuff I am taking off the R33 and selling to fund a new clutch.
  • Comes with switch, unit, T-piece, and bracket
  • Will sell for $100 if I take your stock solenoid & hose
  • Blue Unit
Price: $120 (will install on your car for a slab of beer)
Will Post using Australia Post Express Post Satchel (Tracked)
Autometer Cobalt (2-1/16") Boost Gauge in PSI
  • Will come with small hard vacuum hose from engine to cabin
  • Have for free DIY DIN mount plate (black acrylic)
Price: $50 (will install on your car for a slab of beer)
19x8.5" F and 19x9.5" R HR Racing Pegasus HR-322 Rims
  • Machined lip, gloss black spokes
  • 5x114.3 Stud Pattern
  • Achilles Tyres all round (Approximately 70% tread)
  • 1x small gutter rash
Price: $1000
Pick up only, feel free to fit them at my place if you like too.
Exedy NC10T Used Clutch Plate
  • Used
  • 1.1 Ton Clamping Pressure
  • Surface still good, some heat marks, just machine it all good
Price: $50
Pick up only, CBF posting unless you can convince me with beer :woot:
Contact: PM or This Thread
Cheers,
Johnny :action-smiley-069:
Some photos to get started, I'll take better photos of the rims this weekend.
Looking a tad Mexican here LOL....
Also boost controller is now out of car, as well as boost gauge. Will trade 19s for some proper 17s or 18s
HOW COME NO WANT FULLY SICK WHEELS?
$800 + slab of beer (my way of course) for SAU members only
:yes: :yes:
Boost Controller Sold
Exedy 1.1 ton Pressure Plate, suits R32, R33 GTS-t, R32 GT-R (Pre 1993)
$40 or a slab of Blue Tongue Beer
Fully Sick Spec Wheels, suits RWD/AWD Nissans, Honda Boys forget it, don't bother
$800 (wheels)
$800 + slab of beer (Wheels & Matching Nuts/Lock Nuts)
Boost Gauge
$50 pending meetup/pickup
Boost Gauge SOLD
Boost Controller SOLD
Available:
  • Fully Sick 19s
  • Exedy NC10T 1.1 ton R32 GT-R/R33 GTS-t/R32 GTS-t Pressure Plate
keen on swapping for the wheels in my avatar?18x8s all round with 70% tread on all 4 wheels
ive got same size rims on my skyline atm cost alot in tyres but great for grip and traction
I have a set of black gtt wheels for the swappings... inbox maybe for the negotiatings :domokun:
Do you know what the offset on the wheels are. Unless I missed it in an earlier post?
No idea bro, I have yet to pull the wheels off the car. I bought the car recently and trying to get rid of them ASAP to fund for other stuff on the car
    • The more I think about it, the more I should probably go with a genuine Bride seat and rail set up. But damn the $$$ for a driver and passenger seat + rails!
    • From what I understand, stock internals should hold out for a while even if you run 500 at the crank, no? Especially if you don't run a modern turbo setup that reaches power and torque much earlier than the original twins. My engine isn't unopened either, it has N1 Pumps, head oil restrictor, new crank and cams, new piston rings, ARP head studs and Cometic headgasket along with 2860-5s. Considering everything is healthy this should run fine for a while I assume. Once my engine stops leaking shit everywhere, it'll be tuned to 370 crank first anyway, because I need to legalize the turbo setup. If I end up needing a new engine because my block actually has an issue, even though GTSboy was adamant that the whole porous block story is nonsense, before putting an engine in I'm probably gonna take care of the weakspots.
    • Hah, I have no issues with what you are doing whatsoever! You clearly know what you are getting yourself into. It's just funny reading things like this. "What's that noise?" "Oh, that's normal. That's just the engine not getting any oil. Nothing to worry about. It'll go away in a moment"
    • Yeah I'm keeping an eye on it and might take it out as a once off if this doesn't fully charge. I did some research that said it's normal in equalisation charging. Voltage I thought was 20+ (faulty battery in multimeter) but now its on 15.9v, the max it should go to is 16.2v as per the manual. I'll provide an update once hopefully it's actually fully charged and in float mode. Waiting for it to go to 16.2v and not higher and see what happens. What I suspect has happened is that even though it's not an old battery, I did leave the car turned off for almost 4 weeks at one point then left it off for another 2 weeks which might have erroded the battery and is taking a long time to do this equlisation charge.
