hey guys, just wanting to find out if these will fit my car http://item.mobileweb.ebay.com.au/viewitem?itemId=150790658484&index=0&nav=WATCHING&nid=59062035108
im not really after the look how the wheels sit outside of the gaurds either, i think the offset is +30 and its non turbo so its only got 4 studs.
thanks .
Depending on your height and tyre size if your car is low and your running wide tyres eg. 265 you will need to roll the guards but if its at standard height you wont have any problems
here is an example of 18x9.5+30 it sits nice and flush 245/40/18
http://www.rimtuck.com/setup/view/1290
cheers guys much appreciated, fronts rims are 8.5 so hopefully they wont scrub and my car is sitting pretty low at the monent tyres are just under the guards but it has coilovers so ill just jack it up abit.
How much camber are you running? I'm interested in this almost exact setup
you wont need camber on the back, mine is fine and the teins are lowered to there max on the back, but my tyres are 245/40 on the back,
fronts will rub on 3/4turn and inside of the wheels grates on the hub/strut, id go 9wide on front if doing it again.
id like to run 265 on back but not sure if it will fit though, my arches are rolled , i dont want to damage the panel by trying to arch it ..
anyone done the 265 on this riim?
Sorry mate that's not my car, I'm running 18x9.5+12, you wont need camber arms it will naturally camber in. If your looking at running +30 you will just need to roll your guards you can run 265s shouldn't have any issues as one of my mates is doing it.
9.5 on the front is not that practical, you either have the car sitting a bit high, or you have camber and with camber the front tyres wear out fast and obviously not as much contacting the road in general, but it looks the part and fills the arch nicely :yes:
Not sure what you mean by not practical? they are fine and in fact you have better handling when you have camber set to the front the only down side is camber wear on your tyres but that also happens to any setup if you don't go and have your wheel alignment done properly regardless of offset etc...
For your information you do not have to have the car sitting "high" i had my guards rolled and slightly pulled and i can dump my car on its ass without any issues, i have no scraping issues at all even with full lock. Its all in the guard work.
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
