hi all.
in the process of finishing a project. its an rb 25/30 with a gt3582 hanging off it with big cams and fuel system and going to be looking for above 400 rwkw at 20- something psi..
so i have fabricated up at 3 inch mandrel dump to match the 3 inch outlet on the back of the gt35 and plan to run open pipe the whole way through. it will all be mandrel bent.
Is continuing in 3 inch going to be large enough or do i need to raise to 3.5 or 4 after the dump or once i get past the firewall????
if u need to know specs on anything else to help inform me of correct exhaust sizing then feel free to ask. car has been built from absolute scratch to use as a track car so nothing is really standard and i dont know if any other factors will come into play.
thanks james
https://www.sau.com.au/forums/topic/403386-what-size-exhaust/
noise is not a factor. track only. running a 50 mm gate that will dump to atmo at bottom of firewall.
i was thinking i would need to step up to 3.5. can i get a stainless reducer type of thing that goes from 3.5 to 3 inch perhaps?
im building the car myself so very much appreciate people contributing their knowledge. its very near completion but i like to research my options before i purchase/fabricate/assemble things.
thanks for the input guys, keep it coming. will check that dyno thread too! i do not watch the forums avidly so i do not posess the wealth of knowledge that many of u ppl manage to spunge up out of this forum lol
thanks ash. where do i find a stainless piece that flares from 3 inch to 3.5 or do i need to fab it myself???
gate will def be atmo.... just so i can crack gate and have screammer pipe and get da bitches :P jokes.
thanks guys
    • Hi, just checking. Did you get this stuff made by Vspec Performance and at what price roughly? Looking into (sometime later) also getting such a intake kit, and Trust as well as HKS don't make a full set like this anymore.
    • 2025 Update PRP RB30 Black and Crank Shipped from Austrailia made it and was sent off to the machine shop. -700 to 800hp Service was done to the Block, which included: Inspection Prep and Black Brace to convert engine to 4wd oil Pan  Crank Fully prepped for 1000hp PRP RB30 timing belt kit w/ ALL options Nitto Pistons Nitto I-Beam Rods Nitto Oil Pump New OEM Nissan RB26 Cylinder Head Shipped Supertech intake and exhaust Valves over-sized Kelford 272 cams Mild Lift Nitto Headgasket All of the machine work is completed and next step is assembly and dropping in the new motor.   Upgrades (Changes) from the previous build: Engine Management - no longer using ECUMasters. Haltech Platinum Pro Turbo - Went from twin HKS 2530s with upgraded wheels to BW362SX-E Fuel - 1000cc injectors to ID1430x Single in tank Walbro 450 to Radium External Surge Tank w/ 2x Walbro 450s     I am looking to be back on the road by the end of summer. Wish me luck! monthly updates should be coming!
    • Realised I never posted this , also I never got a price
    • I'm glad to hear you've joined the SKI club. Spend the Kids Inheritance.
    • I have a VALCON if anyone wants it, I have no idea why you'd want to have VVT specifically broken out of the ECU as opposed to running it off the FCON/whatever standalone you have.
