Unfortunately for me it has come time to sell my R32 GTR.
The car has a Genuine Veilside wide body kit (imported from Japan at a cost of $6780) fitted to it currently unpainted so it is in Black Gel coat ready for paint or to be moulded in depending on what look you are going for.
It has a large Carbon fiber rear wing and a genuine JUN front carbon lip. I also have a JUN rear diffuser to go with the car if it goes for the right price.
Currently the car has a set of 18x10 Lenzo D1R wheels wrapped in pirelli P-Zero Tyres 265/35/18 all round.
Custom made LED Rear taillights, they are one off items
Has HID fog lights and comes with HID kit for the headlights, which have been converted to H4, Hi and Low Beam in one instead of being separate.
Battery Relocated to Boot with 0 Guage wiring throughout, cut off switch mounted on box.
Suspension Modifications:
Full DGR coil-over suspension to custom specifications, upper pillow ball mount, 30 way adjustable
Front and rear Cusco Sway Bars, Front 24mm, rear 30mm
Rear fully adjustable camber arms
Hicas Lock Bar
All Hicas system removed including all piping and standard power steering lines modified to eliminate complete system.
Stainless front strut brace
Carbon fibre rear strut Brace
Brakes:
Full set of Brembo calipers off an R33 GTR V-Spec With new DBA slotted rotors all round front and rear and ebc green stuff pads.
Engine Modifications:
Full Head Rebuild:
Fully Shimmed lifters with Titanium Shims
Big HKS camshafts, Stepped camshafts, Intake 272deg 10.20mm lift, Exhaust 264deg 10.0mm lift Head has had channels Ground to suit the Hi-Lift Camshafts
Ported and Polished Head,
New Bronze Valve Guides
Ferra Stainless Intake and Exhaust Valves, Multi Angle Valve Machining
Tomei Titanium Valve Springs
Tomei Titanium Valve Retainers
ACL Race series Cometic Head Gasket
All work was completed approximately 2000kms ago
Powder coated rocker covers in Bayside Blue
Full Alloy radiator
HKS Fuel Rail
Seimens Dekka 846 cc injectors serviced, and spray pattern altered by Deutschwerks in the USA
Walbro 255 LHP Fuel pump, 255L per hour High Performance
Huge Greddy Inlet Manifold, Split type
Custom Ignition setup:
LS2 Truck Coil packs
Custom Wiring loom and alloy mount
Custom Eagle 10.5mm leads in Blue
This setup creates 6-10x's more spark than standard packs and eliminates the need for an igniter there is also less stress on the coil-packs as there is air circulation under and around the packs cooling them. Each pack also has a heat sink to allow it to run more efficiently and reduces the chance of failure.
Tomei SUS304 Expreme Headers
Tomei SUS304 Expreme Dump Pipes, The Large type, 92mm outlet
Custom exhaust 'Y' Pipe
Venom 4.5' Hi Flow Cat
Apexi N1 4" Exhaust, Not available in Australia
Nismo LM Turbos, These Turbos are a Hibrid Turbo developed By Nismo for the GTR, They are larger than N1 turbos and have been cleared by CAMS for use in events such as the Targa Tasmania because they could be optioned onto a limited run of cars. They are Group A Nismo GT LM turbos. They were rebuilt and Hi-flowed by Turbologic approx. 7500km ago
Apexi "M's" intake kit
All drivetrain fluids changed with Amsoil Sever Gear and Diff oils changed.
Brass button Clutch
R32 GTR V-Spec Rear differential
Full Bottom end Rebuilt by previous owner with CP Forged Pistons, new rings and an oil restricter has been put into the block to stop the over oiling issue that the early GTR engines had.
HKS Oil Cooler and Full oil filter relocation Kit With all speed flow fittings
Comes with a Tomei Oil pan baffle that is not yet fitted
When the car was Tuned it was running 557.4 Hp at the wheels
Interior:
All systems are controlled by and apexi Power FC with a Hand Controller.
It has an Apexi AVC-R, electronic boost controller with scramble Boost Option
It has a set of Auto Meter Cobalt series Gauges monitoring engine conditions, Boost/Vac, Oil Temp, Digital Oil Pressure and Digital Air Fuel Ratio.
Has a flip out Pioneer AVH-P-5950dvd DVD headunit
German maestro 6.5 inch speakers in the rear, Carbon Fibre cones, Very high end speakers ad a pair of pioneer 6" speakers in the front
I have all receipts for most of the work done to the car, and receipts for most of the parts, some were purchased off forum members from here. Car has rego until september this year.
The Bad Point: In March while driving the collars in the oil pump failed causing a sever drop in oil pressure. This has caused the engine to spin a big-end bearing. Car still starts and drives but it will need to be trailered to avoid damaging the engine further. I no longer have the time to fix the car which is the only reason I am selling
If you have any questions give me a call on 0434817247 or PM me here and I would be more than happy to answer any of them. Also if you would like to come down and see the car let me know and we can organise a time for it.
The car is in Wollongong about 1 hr south of Sydney.
I am taking some pictures today and going to put some up but if you would like pics of specific things let me knwo and send me an email and ill get them to you.
The car has a had a lot of time and money spent on it, looking for $13,000 ono.
Edited by Matnos
Have tried to upload some pics and it says they are too big, if people want to send me their email address i can send you some photos.
Also forgot to mention that the car has a R32 GTR V-spec Alloy bonnet, and evidently adjustable cam gears and gates racing timing belt, just incase people were thinking I was silly having big cams and no gears :-P
Yeah thats correct, i had the choice weather I wanted to ge the other front and rear bars but didn't want to go that way, still wanted a sort of semi stock look still, just fat...
Im surprised that the front bar stretches that far to line up with the guards. Does provide a nice stock / fat look though.
    • Yes, it is indeed that time of year again - the time has come once again for us to sit and discuss the state of our club, and any/all future possibilities! And yes, it is the perfect opportunity to sit and have a bite to eat and/or a drink with all SAU NSW members! Every wondered whether there is more to SAU NSW than just our beloved cruises? Well this is ALSO the best opportunity to quell your curiosity! We discuss everything SAU NSW from current financial position, performance of the club over the past year, the good things we did, the bad things we did, as well as the things we could do better or different! Not to mention, we talk plenty of car talk too.. After all, we're all passionate car enthusiasts! So without any ado, please save the date, and come down and get involved!   When: Sunday 4th May 2025 Where: Toongabbie Sports & Bowling Club - 12 Station Road, Toongabbie Map: https://tinyurl.com/saunsw-agm Time: Meeting will commence at 1.00pm. As usual, lunch from 12.00pm!   Agenda Items: - President's Report - Treasurer's Report - 2025 Committee Elections - State of SAUNSW & moving forward - Future Events & 2024 Calendar - Further Motions & Agenda Items - Open discussion   To our members who are also on the forum, if you would like to discuss any particular item, or have any ideas for the future of the club, please note it in this thread for discussion at the AGM within the NSW Members section of the forum. If you don't have access to the Members section of the forum, then get in touch with us! A note to our members: We remind you that as per constitution, nominations for committee positions close 21 days before our AGM (Saturday 12th April 2025). ALSO, by 12th April, any motions must be put forward, for discussion as agenda items at our AGM. Please head over to the Member's Section of the SAU Forum to post your nominations and any items you wish to be discussed! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • We're bringing Pizzas back!! Pizza Runs, to be specific... We had a practice Pizza Run a while ago, and everyone has been screaming for a proper one... So you've asked, and now we're delivering! Since your tastebuds are tingling, feast your eyes on the event details: Date: Saturday 19th April 2025 Meet Location: Parking Lot - 1 Parkview Dr, Sydney Olympic Park Meet Time: Meet at 5.30pm for a 6.00pm departure Destination: Talotta's Pizzeria, 1-3 Bridges St, Kurnell Map: https://tinyurl.com/saunsw-talottas We'll meet at the carpark on the corner of Parkview Drive and Australia Avenue in Sydney Olympic Park. When we leave the parking lot, we'll head down Australia Ave, and turn right onto Homebush Bay Drive at the large roundabout near DFO. As soon as we turn onto Homebush Bay Drive, we will be turning left onto the M4 to drive through the new M4/M8 tunnel! Everyone loves a bit of RB action through a tunnel.... We'll exit the tunnel at the Gardener's Road exit, and turn onto Princes Highway, where we'll follow it onto Rocky Point Road and then onto Taren Point Road. Once we reach Miranda, we'll turn left onto Captain Cook Dr, where we'll continue on straight until we reach Talotta's Pizzeria for some pizza goodness!!! There is a small carpark at the destination. Limited spaces are available, but there will be plenty of street parking in front of Talotta's There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • The time has come once again, for another SAUNSW Sunday Session! You all know the drill by now, fam... This is the perfect event to catch up with the SAUNSW crew, hang out for a coffee and a bite to eat, and get in some photos and friendly banter! So without any ado, here are the details: Date: Sunday 6th April 2025 Meet Location: Penrith Krispy Kreme (at Penrith Panthers - Panthers Place, Mulgoa Rd, Penrith) Meet Time: 8:00am Map: https://tinyurl.com/saunsw-penrithkk This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Welcome to the new year, gang! We've ticked over into 2024, so as usual, we're starting the new year with a chill social out at Aqua Golf! So without any ado, here are the details: Date: Saturday 22nd March Location: Aqua Golf - Penrith Panthers Time: 4:00pm Map: http://tinyurl.com/saunsw-aquagolf All you need to do is bring yourselves down to Penrith Panthers to come and say "HI", hang out, and maybe hit a few golf balls at the drive range. Who knows where the night may take us... What we do know is that there are plenty of food options available at the Penrith Panthers complex. For those of us keen to hit a few golf balls, prices start from $7.00 a bucket. Aqua Golf is open til late, so we have plenty of time to have a few hits and laughs with each other! This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks all! Looking forward to seeing you all there!
    • Kicking off our first Sunday Session for 2025, we'll be heading to the delectable Self Raised Snack Shoppe!! Get your tastebuds ready for a mouth-watering toastie and coffee! As always, this is the best place to meet up with the SAUNSW fam for a coffee, bite to eat, and a chat! So what are you waiting for? Block out the calendar, set your alarm in the morning, and come down to hang out with the SAUNSW fam! Date: Sunday 9th March Meet Location: Self Raised Snack Shoppe - Shop 4, 8/20 Sarsfield Cct, Bexley North NSW 2207 (carpark entry via Slade Road) Meet Time: Meet at 8:00am Map: https://tinyurl.com/saunsw-selfraised This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAUNSW event and will be run under a Motorsports Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehaviour will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
