That PC is down to $1750 :P
But nah f**k it... My luck has been so epically bad lately that i'll get the only shafting. It'll have a lot of backlight bleed or something really fken annoying.
Plus my Sammy 24" is still rocking along without issues. If these monitors keep selling though over time it will push the prices of the other ones down potentially given they have only seemingly been around for 4-5 months. Give it 12 months, quality of the Koreans to improve a little (and likely small price rise), and it could well do us all wonders
I am and I shall.
Tax return has been lodged so barring the ATO deciding to look at it more carefully, I should have my return within a week or so. Ordering a monitor will be the first thing I do once it arrives.
I'll be sure to document everything I can and give everyone a full rundown on what I think of it.
Yeah. I figure for an extra $20 I may as well. While 5 dead pixels wouldn't bother me in the slightest, I hope the extra money will also reduce the likelihood of bleeding, not that that is likely to bother me a great deal either.
I am and I shall.
Champion!
Feck I hate banks.
Paid of my CC yesterday, money's gone from my account but not yet on my CC. It's utter bullshit that it takes multiple days to arrange something like an electronic transfer of funds.
I want my CC paid off so I can use it to buy my damn monitor >_<
Right, CC paid off, but now I'm not sure which one to buy. The Q270 or the 2703?
Do I pay $60 for pixel perfect or take my chances? I can't see 5 dead pixels bothering me but wonder if it means it would be less likely to have bleeding.
Time for some more research. I will be ordering tonight.
Order made!
Gone for a pixel perfect Q270. There seems to be a bit of contention regarding whether or not the 2703s are "S-IPS" or just IPS. S-IPS are superior, apparently.
I figured $60 for piece of mind was a bargain,l so went for no dead pixels.
I will record and report each step of the process. From reports there's a good chance I'll have it by the end of the week.
So, here it is:
Comes well packed.
Everything is covered with that cling film. Once all unpacked and unwrapped it apparent that it's perfect. So far so good.
Set up took a couple of minutes. I find it to be very stable. The base is one thing you read a lot of negative comments about, but it's proving to not be an issue.
The picture is everything I expected; brilliant!:
Next to my Benq 24":
Overall I'm very impressed. Battlefield 3 looks amazing on it. I've got Crossfired 6850s and it runs on High with >60FPS on 2560x1440.
I can't see any reason it'll go belly up. I haven't found any online reviews which suggest they don't last.
So far I'd highly recommend one to anyone thinking about it. The quality has impressed and surprised me.
I'll be sure to report back should any issues arise.
Quick update, still totally in love with my new monitor. It's taken my Beef3 game to a whole new level :)
I'll try and find some time tonight to investigate OC'ing it and report back with results.
I don't do any photo stuff, but it's fast, bright, colour true (as far as I can tell) so hell yeah, I can't see why it would be anything other than shit hot for photoshop and lightroom.
It's every bit as good as the 27" iMacs our developers at my work use.
Look carefully at your Avatar and you can see the difference, especially around the front bumper. It's much more pronounced when I look at the image on my 24 and then move it to the 27 but you'll lose it because your monitor is likely 1920x1080.
Catleap
BenQ
Would you recomend it for use with photoshop and lightroom? I'm looking for something thats good for gaming plus a small amount of photo editing.
They are a IPS panel, so yes certainly a good option for photo - without the $1000 cost of a bigger brand name.
But do remember there is always that element it won't be perfect.
Still looks good though, colours are much better indeed
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
