  • Replies 71
Hi Roy, I'm heading up saturday morning about 7.30am from Southside of Canberra.
I expect a fair few from here as it's just up the road.
Weather is looking good up that way for Saturday. 18 and a sunny day
Well I haven’t driven on an airport run way before so was not sure what to expect but really disappointed on the condition of the run way. Starting on the worse section gravel everywhere, no chance of even using launch control pulled away from 1500rpm and still wheel spinning and wheel spinning into 3rd gear. Lose gravel down the whole runway and braking area was bad again with 2 large bumps at the end. Only did one run as I didn’t want to stuff my paint work with stone chips and damaged my front lip splitter on the braking area over a bump. I may be fussy as I try and look after my car but speaking with others they were not to impressed over the track conditions.
That’s my little rant....
From a spectators perspective the masses were very dissapointed with the organisation
The barriers were placed so far back you could not hear or see the cars.
Scoreboard times were not posted untl after the 4th group of cars had there first run
There was no commentating (at least until after the 4th group was finished) and even then it was Meh and sporadic
Our entertainment was the weekend traffic being pulled over by the police just outside the fence line which we could see clearly
I know how you feel battling for traction, I was trying to do it with a 2WD! It meant that I was not able to run my car anywhere near its peak power unfortunately, would have loved to have full boost in it from 3rd gear as it hooks up on the street and Cootamundra.
It is a great concept, it's a shame the surface was not better.
I didn't realise how bad the damage was until I changed my wheels this morning, the rocks made an absolute mess of my side skirts (looks like they've been sandblasted and fibreglass now exposed), wheels chipped real bad.
I'm not really too fussed when it comes to things like that, but I'm sure it would be enough to turn car lovers away.
Adam did mention hot-mix for the first 140m next year, would definitely make it more competitive, would be nice if they could extend that to 400m :)
Ultimately, it is runway racing. It is not a perfectly prepared drag strip. There will ALWAYS be stones on it, regardless of Cooma or Temora or anywhere else. However, we are taking steps to make the launch area MUCH better for next year with hot mix off the line to get the cars underway. We also received a lot of positive feedback about the fact that at least we made the effort to try and clean the start with brooms
Thanks for the feedback about the end of the runway. I spoke to most of the competitors at the finish line throughout the day. I asked nearly everyone who i did manage to get a chat with up there as to what they thought of the start, middle and finish, and the only comment was the first 100m was garbage. Most competitors mentioned that it was no worse than anywhere else. Again, Thanks for the feedback on the finish.
Good to see that there was a decent sized scoreboard there at all. We had a power supply issue for the modem from the timing guys
Barriers will be 70m closer to the track next year, so going from 140m to 70m away. This years distance was a requirement by our DSR Permit and track inspection, with the room to move closer if no issues this year
Correct
If you guys have any other feedback, please feel free to email us at [email protected]. The more we know, the more we can keep doing or improve if needed
Cheers
The stones were no where near as bad at Temora,Im not laying crap on the event,just saying it was bad.Alot of the cars entered are beautiful street cars and thats a definate turn off.
    • I’m only posting this cause I thought I had seen a bad review on these somewhere before. Any feedback? Would you guys recommend that if I do buy these I send em to RC to have em checked before installing. Or any other suggestions?   https://www.ebay.com/itm/114009965865?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JDl-15yLQ8C&sssrc=4429486&ssuid=QTzlFXB1S-S&var=&widget_ver=artemis&media=COPY
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
