Hey guys does anyone know who this engine bay belongs to?
Trying to tack up some history on the car so any help will be appericiated.
Also by just looking at the engine bay what seems aftermarket except the turbo catchcan, coilpacks, radiator.. and most importantly power output potential??? just by the pic
cheers guys
https://www.sau.com.au/forums/topic/403509-anyone-know-this-r33-gtr/
Oh and you'll need to replace the top radiator hose and do the rocker cover gaskets
how would u know this and the gaskets?
also with this setup it would 100% have had a engine rebuilt?
cheers
trust stickers are worth 200hp each, and the fuse box that they painted mardi gras yellow is worth 20hp.
To be serious, If we could tell you what it's power output is just looking at a photo we would be charging for that service.
As was mentioned above that top radiator hose is rooted (top of radiator has dried coolant on it that looks like it has had stop leak put in it)
Best bet if your looking to buy it go into ERD and get the guys down there to do a pre purchase inspection and if you want power figures and are willing to pay book it in with Sean over at EFI and get a power run done.
So many people ask this sort of question on a forum how about asking the owner where he gets his work done and check with them what has been done and if it has been dyno'd.
Is the owner a member of this forum if so check previous posts to see if the car has had an known issues and if they were solved here.
I wouldnt have posted this if i had any info on the car, its interstate so cant inspect it. Just want to know as much as possible from this pic thanks
The car is fairly heavily modified. It has an aftermarket standalone ECU and has been fully reqired. Looks like a reasonable wiring job too. The car looks like its been looked after to some moderate standard but as you can see from my earlier posts it will need a tiny bit of TLC.
If the turbo isn't blown, it makes more than 150psi compression on all 6 cylinders and it's not flowing oil out everywhere, I'd say you've got a reasonable looking car. Expect it would sell for somewhere around the 20-25k mark depending on what else it has. You can't see the cams so they cannot be identified.
Get a compression test, oil pressure test and possibly pay a mechanic that is local to the car to drive it and give an opinion. Pick a specialist workshop nearby to the owner. Buying interstate isn't fun, but neither is buying a lemon if you don't check it out properly. I would suggest flying over to see the car but you may not know what you are looking for.
Biggest problems after engine etc will be body damage from an accident so check for splitting in the wheel arches at the seam near the chassis rail.
Failing that, what state is it in? If it's in QLD I could take a look for you if the guy wants to bring it in.
Bumpp, im going to inspect the car guys hopefully if i find flights next week, can someone tell me what to look for in a modified car like this?
And also since its using the stock intake manifold and rocker cover could this mean the engine isnt rebuilt/forged? And also howmuch would the a price range to forge/rebuild this engine if it requires later on?
Sorry for all the question guys ive only had stock 34gtrs before, nothing modified. Cheers
mate, honestly spend $75 - $150 and get it to a mechanic that works with imports...
could save you thousands... or give you ammo to bargin the price down...
even if its mint you could easily get 5-7% off anything these days and that will pay the mechanics fees ten times over...
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
