Hi,
I finished changing the fluids on the 4wd system.
Now when I give it a little the engine warning light comes on. Drive it sedately and no problems.
Any ideas what causes this?
Oil changed within 5000Km, plenty there.
My wifes driving up to Bundy a 600Km drive on Friday, so hopefully sort it by then.
Cheers,
Brendan
https://www.sau.com.au/forums/topic/403522-engine-warning-light-on-a-c34-rs4/
Hi Brendan, didn't you get a consult cable? could check the error codes with some consult software. There is a way to check the dtc's by shorting 2 pins on the consult plug and have it flash the error code with the check engine light, i think there is a procedure in the workshop manual for this.
Hey mate I have the same problem as well! I found it goes away as soon as you touch the throttle again. Oxygen sensor maybe? How many kms have you done?
Yes I was going to say 02 sensor, when mine went the engine light would come on when idling at lights, as soon as u got going it would switch off again so yeah check your sensor
Thanks
I was thinking maybe the FWD part wasn't 100% before, now the fluids are ok its' working harder?
My wife reckons she hasn't seen the light any more.
Yeah i'll look into it.
Good tips.
Ours does the same, give it a bit and she'll come one back off and after a little bit it turns off, been like that easily 6 months now though. It was also hesitating or running rough like there was a coil pack issue, but only during summer - now that it's winter its not doing it.... does this sound like it's coil packs for sure?
How many kms have you guys got with this problem? I have 98xxx km on the clock
We all know the coil packs go around the ~100k area so I suspect mine are in their way out because of the heat?
Note my coil pack cover is off so the hot air doesn't get traped
Workshop manual for a C34 S2? WHERE?????
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
