Hi,
I finished changing the fluids on the 4wd system.
Now when I give it a little the engine warning light comes on. Drive it sedately and no problems.
Any ideas what causes this?
Oil changed within 5000Km, plenty there.
My wifes driving up to Bundy a 600Km drive on Friday, so hopefully sort it by then.
Cheers,
Brendan
https://www.sau.com.au/forums/topic/403522-engine-warning-light-on-a-c34-rs4/
Hi Brendan, didn't you get a consult cable? could check the error codes with some consult software. There is a way to check the dtc's by shorting 2 pins on the consult plug and have it flash the error code with the check engine light, i think there is a procedure in the workshop manual for this.
Hey mate I have the same problem as well! I found it goes away as soon as you touch the throttle again. Oxygen sensor maybe? How many kms have you done?
Yes I was going to say 02 sensor, when mine went the engine light would come on when idling at lights, as soon as u got going it would switch off again so yeah check your sensor
Thanks
I was thinking maybe the FWD part wasn't 100% before, now the fluids are ok its' working harder?
My wife reckons she hasn't seen the light any more.
Yeah i'll look into it.
Good tips.
Ours does the same, give it a bit and she'll come one back off and after a little bit it turns off, been like that easily 6 months now though. It was also hesitating or running rough like there was a coil pack issue, but only during summer - now that it's winter its not doing it.... does this sound like it's coil packs for sure?
How many kms have you guys got with this problem? I have 98xxx km on the clock
We all know the coil packs go around the ~100k area so I suspect mine are in their way out because of the heat?
Note my coil pack cover is off so the hot air doesn't get traped
Workshop manual for a C34 S2? WHERE?????
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
    • No, with a twin plate clutch flywheels and clutch pressure plate/friction disks go together. Only clutch where that isn't the case is the Uniclutch but they currently don't make a pull version for the Getrag R34, just some other cars. Personally the flywheel is as light as I'd want it to be. It already drops revs faster than I want to shift normally and I blip the throttle again to rev match on upshifts.
    • Are there any other lighter flywheels that can be used with nismo coppermix twinplate system? Id like to gave the revs pick up faster than oem
