Get it through street to track. He gets them from ATP turbo in the states an I reckon it would be half the price including postage to your door, compared to the gcg link.
The dollar is pretty decent at the moment as well
Edited by Mitcho_7
  • Replies 57
wow expensive yes!, but then again that is a genuine Garrett housing and EVERYTHING else is aftermarket, they are apparently cast with different materials as well, some high nickel ni-resist material something or rather =S
More or less true yes, but its not worth 900.
Like someone said already itd be worth half that out of the states. Actually let me confirm that...............................
http://www.atpturbo.com/mm5/merchant.mvc?Screen=PROD&Store_Code=tp&Product_Code=ATP-HSG-037&Category_Code=GTH
Same genuine item, with a realistic cost (still a lot of money but its swallowable).
I hope that helps.
http://www.atpturbo....tegory_Code=GTH
I hope that helps.
So this will fit the GTX3076R as well?
different units, different part numbers GCG listing is the dearer version with upgraded wastegate valve.
Still doesn't matter, with the way the dollar is now why wouldn't u buy one overseas hahaha xD
On a different note, +1 on something wrong with set up hahah, blocked/restrictive cat perhaps? you can still make that same power with a 0.63a/r + more, will just run a bit hotter, don't necessarily need a 0.82a/r
They are interchangeable, only thing that changes in a GTX unit is compressor wheel and surge slotted comp cover
Edited by OoskylineoO
I had the .82 IW garret on mine, then the .63 external now the .82 external.
.82 was a bit laggy, full boost around 4200, .63 full boost by 3500, .82 external at 3800.
all different to drive
Which do you prefer? Do you have a build thread etc? Interesting to hear the differences between the housings :)
I thought gt3076 had a port shrouded compressor inlet as well?
Maybe it was just a pic of the gtx advertised a the gt that I have seen...
You can have it with or without... Mine has the 4in inlet and surge slots, sounds mental too...
yeah id like to know what was preferred most also
No build thread, sadly a bit too muchtime and effort these days. mostly just spam my Facebook with update pics
The .82 internal did its job, but the control of the internal gate is destroyed by external. From that experience if i was to put a large turbo on a car again, IW wouldnt even cross my mind.
the .63 was good, and to be honest it would probably still be on the car if it wasnt for an issue we thought i was having when i put the .63 in there. (turned out not to be the turbo) which was good but id had already bought the .82 to try and solve the issue.
the .82 external isnt very laggy imo, full boost in 4th is around the 3800 mark (19psi) and im pretty happy with that for what it is. overlaying the .63 and the .82 on the dyno the .63 is on about 300-400rpm earlier, but did make a little less in the top end, In saying that 2 mates have the same set up but with a .63 on their neo motor and didnt see the fall in the top end that my 33 did
End of the day car is a daily that sees a bit of track work, so for that effort the .82 is staying on.
the last 2 times we went to do a power run on 19psi turned out to be 40+ degree days. so we never got a proper run. since then ive had a low mount manifold made and installed, and tomorrow ill be going from 3" stainless steel to 4: titanium, so ill try and get some kind of power run in next week
Josh
What pressure springs are you guys using in your wastegates, for the earliest response is it best to run as close to the pressure you want
for example, a tial44mm external and want to run say 20psi, what spring pressure would you want ( assuming you have an electronic boost controller)
pretty sure the one in mine is a 12psi spring, so wondering if it would get better response with a 16psi spring in there?
I run 1 bar of spring, then use the mac valve to push boost pressure on to the top of the gate, helping hold it down. Works better with a 5 port mac valve like mine but the 3 port ones can be setup like that too. I can hold any boost now.
looking at my boost curve seems like the spring or the duty cycle was not done right, maybe resulting in a lazy boost curve etc.. looks like its heading for full boost at or before 4000rpm which is whats the norm round here but then take a further 500rpm or more to get from 15 to 18psi, so yeah i think the spring may need changed to a 1 bar spring and the controller adjusted for a more aggressive build up,
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
