Hey fellas,
It is the time for me to replace my bruised and battered 400R front bar. However when i purchased the car it was already on there,
Have looked at m spec front bars and gtr style front bars. Basically my question is ; My r33 (4 door) S1 has a GTR Reo on it, with a fmic and oil cooler on the corner of the passenger side mounted on some brackets, Do i look for a s1 front bar or a r33 GTR front bar style. And do i need to change the reo ? as my reo is still in one piece with no cuts/chunks taken out of it...
here is a picture that might be able to help you guys if im not making sense at all
GTR REO with FMIC and OIL COOLER LINES
PIC WITH OIL COOLER SHOWING
COOLER ITSELF.
https://www.sau.com.au/forums/topic/403543-r33-front-bar/
ive gota r33 gtr style front bumper,genuine gtr bumper doesnt seem to fit aswell if u dont have the gtr gaurds.
i bought mine off a member on this forum and it fit very well. looks alot better than standard.
but u need to buy genuine gtr indicators or u can mount after market ones, but genuine looks tops
https://www.sau.com.au/forums/topic/403543-r33-front-bar/#findComment-6422906
  • 3 weeks later...
I believe the bonnet latch is also different.
Pretty sure with the series 1 headlights a rubber spacer/ bushing sort of thing needs to b added or removed, can't remember which 1.
If u want a gtr front end just buy a gtr, they are cheap enough these days. That way u get the best of everything
https://www.sau.com.au/forums/topic/403543-r33-front-bar/#findComment-6450700
    • Come to Eastwood, you'll get plenty of that 馃ぃ
    • Oof, I will forevermore have those shredded gears in mind whenever someone talks about showing mechanical sympathy towards their car. Thanks for the photos, fascinating stuff!
    • Curious to see how the SpeedTek stuff holds up
    • The holdups last year were drivetrain related. I had the car out right after getting the bearing issue resolved. Third launch and the car didn't move after releasing the clutch. It had sheared all the engagement teeth off the 1st gear.    Thankfully no other damage was done. I set an aftermarket gear beside an OEM gear and found that the engagement teeth on the OEM gear were much larger and better supported. Looking through my bin of spare transmission gears I found that there are two types of tooth on the OEM first gears - the larger tooth and the smaller tooth. It looks like most aftermarket gearset manufacturers base their design on the smaller tooth. OEM large tooth left - Speedtek, OS Giken, etc or OEM small tooth right Decided to give that larger engagement tooth a try. Pressed the ring off an OEM gear and sent it to a transmission manufacturer here in the States. They did their "faceplating" operation with my synchro ring on the Speedtek gear.   I reassembled it, took it back to the track and promptly destroyed the gear itself.  I'll rebuild this and use it as a spare - thankfully just first gear and the countershaft are damaged beyond repair. Definitely disheartening but my welded on engagement tooth ring held up!  Moved to Speedtek's dog engagement design as the gears appear to be much stronger. So far they have taken much more abuse at the track. Also scored a Stillway lockout from the Netherands for super cheap. It's for some other RB transmission so it took a bit of fabrication to fit but honestly a very easy job. I also had to heavily modify the gates as they were very different.   Then for some reason at the last test and tune a silicon coupler below the throttle blew off and took out the radiator and fan. Thankfully it was in the burnout box and not down track. This car is really beating me up - I still haven't made a pass in it. Ran it through the gears many times on the street but it keeps biting me at the track.  Currently in the process of replacing the radiator and remaking the throttle pipe to remove the coupler and use a cast 90 and a vband. I WILL get this thing down the track...
    • Covers most of the above points really. There's a few exceptions but most just see driving as an irritating but necessary task they must complete if they want to get anywhere on time. Also see it as a good time to show their awesome multi-tasking abilities on their mobile and/or doing their makeup.
