Is there anyone that has tried or even considered sticking a VH45DE in an R33 GTS25t? I was curious if it would even fit between the towers.
See the article below for short writeup on the VH45DE (208kW, 400Nm)
http://www.autospeed.co.nz/cms/article.html?&A=0206
http://www.jpcar.net/modele.htm
https://www.sau.com.au/forums/topic/40358-vh45de-in-r33-gts25t/
  • Replies 41
Damn . Soo much for being original.
Hmmm wonder how much i can flog my RB25DET, Power FC, Cut and shut Plenum, Stainless intercooler plumbing, ARE intercooler (600x300x75), 3.5inch dump of turbo for and how much a 2002 VH45DE, Autronic, full exhaust and fitting will cost.
If there are only mm spare when fitting a VH45DE would a VH41DE fit more easily.
Not that i am a V8 head but i would love to hear what that guy from QLDs skyline sounds like.
http://www.freshalloy.com/site/features/te...ines/home.shtml
What gearbox did they use in the S13??
I checked with Dellow and they do not do an adaptor plate for the RB25 box.
I would probably go for the auto box anyway since i am tired of shifting gears all day every day. Its alright when you are racing to have a manual but for getting through traffic auto is the way to go and with 4.5ltr V8 in a R33 it would be relaxing.
KamikazeR33 who is SST? Do you have a phone number?
redline2003 (tongue in cheek when i say this) for even suggesting a gen3 motor you should delete that post. Of all the things an overhead valve truck motor in a "performance" car...... That is a joke.
Still on redline2003. I wouldnt stick this motor in an NA shell, the brakes are too small and yes NISSAN ALL THE WAY. I have been hunting around for some way of getting a manual behind the VH45DE but the only way i can see i can get a V8 in my skyline and keep it manual is to use a 1uzfe (toyota 4L V8) which i am not really interested in at all. But as i have said previously i would probably stick with an auto (just wish they had a 5sp auto).
I have checked a few wreckers and they want arounf $2800 for a 1994 Ifinity half cut. I couldnt get a turbo high flowed and a my RB25 bolted together with an RB30 for that plus fitting. Ontop of that the VH45DE is an incredibly tough motor. I am told by a mate it has 6bolt mains and the crank is drop forged.
My friend has the only V8 silvia in Perth.. that we know of. and its VH41DE not 45.
He did the whole conversion himself with a little help from a good engineer, took him a long time to do, including deciphering an entire Infiniti loom, modifying steering column & rack, entirely new cooling system including redesigned water pump outlets. Some would say there wasnt alot done to it to get it to bolt in, but its the many hours spent on the small details which made it work. Those who heard it at Speedworks when it was started will testify to its quality :rant:
Wouldnt be too difficult to do it in an R33 of course. Little bit more engine room and it actually might fit under the bonnet (which it doesnt on a silvia).
And I wouldnt get too confident about having a manual. My mate has stuck with the Infiniti auto for now since every option he pursued, such as 300ZX boxes, RB boxes and just about anything else with a Nissan badge, didnt bolt up.
What you really want is a VK56DE out of a Nissan Titan! :)
Red17
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
