Is there anyone that has tried or even considered sticking a VH45DE in an R33 GTS25t? I was curious if it would even fit between the towers.
See the article below for short writeup on the VH45DE (208kW, 400Nm)
http://www.autospeed.co.nz/cms/article.html?&A=0206
http://www.jpcar.net/modele.htm
https://www.sau.com.au/forums/topic/40358-vh45de-in-r33-gts25t/
  • Replies 41
Damn . Soo much for being original.
Hmmm wonder how much i can flog my RB25DET, Power FC, Cut and shut Plenum, Stainless intercooler plumbing, ARE intercooler (600x300x75), 3.5inch dump of turbo for and how much a 2002 VH45DE, Autronic, full exhaust and fitting will cost.
If there are only mm spare when fitting a VH45DE would a VH41DE fit more easily.
Not that i am a V8 head but i would love to hear what that guy from QLDs skyline sounds like.
http://www.freshalloy.com/site/features/te...ines/home.shtml
What gearbox did they use in the S13??
I checked with Dellow and they do not do an adaptor plate for the RB25 box.
I would probably go for the auto box anyway since i am tired of shifting gears all day every day. Its alright when you are racing to have a manual but for getting through traffic auto is the way to go and with 4.5ltr V8 in a R33 it would be relaxing.
KamikazeR33 who is SST? Do you have a phone number?
redline2003 (tongue in cheek when i say this) for even suggesting a gen3 motor you should delete that post. Of all the things an overhead valve truck motor in a "performance" car...... That is a joke.
Still on redline2003. I wouldnt stick this motor in an NA shell, the brakes are too small and yes NISSAN ALL THE WAY. I have been hunting around for some way of getting a manual behind the VH45DE but the only way i can see i can get a V8 in my skyline and keep it manual is to use a 1uzfe (toyota 4L V8) which i am not really interested in at all. But as i have said previously i would probably stick with an auto (just wish they had a 5sp auto).
I have checked a few wreckers and they want arounf $2800 for a 1994 Ifinity half cut. I couldnt get a turbo high flowed and a my RB25 bolted together with an RB30 for that plus fitting. Ontop of that the VH45DE is an incredibly tough motor. I am told by a mate it has 6bolt mains and the crank is drop forged.
My friend has the only V8 silvia in Perth.. that we know of. and its VH41DE not 45.
He did the whole conversion himself with a little help from a good engineer, took him a long time to do, including deciphering an entire Infiniti loom, modifying steering column & rack, entirely new cooling system including redesigned water pump outlets. Some would say there wasnt alot done to it to get it to bolt in, but its the many hours spent on the small details which made it work. Those who heard it at Speedworks when it was started will testify to its quality :rant:
Wouldnt be too difficult to do it in an R33 of course. Little bit more engine room and it actually might fit under the bonnet (which it doesnt on a silvia).
And I wouldnt get too confident about having a manual. My mate has stuck with the Infiniti auto for now since every option he pursued, such as 300ZX boxes, RB boxes and just about anything else with a Nissan badge, didnt bolt up.
What you really want is a VK56DE out of a Nissan Titan! :)
Red17
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
