Hey,
Im about to look into buying a dump and front pipe from my skyline (r33) along with a hiflow cat (or no cat :)). At the moment my exhuast is catback HKS Super Dragger and i was wondering if there is any different between me install brand names parts (HKS) or custum made parts.
I know brand name is alot pricer but is it worth it?
Also i was told that APexi N1 Exhuast is the best is it worth selling my HKS system and upgrade to a full turbo back N1 system
Thanks Mike
https://www.sau.com.au/forums/topic/40359-brand-name-dump-front-pipes-question/
just get a custom single piece dump and front pipe, goto quickfit exhaust in morley, theyve done a lot of perth sau members cars and heard nothing but good feedback.
i can't see how the apexi n1 is better, it's different.. it is louder than your super drager would be. your super drager catback is 95mm (3.74in) and apexi n1 is only 80mm (3in), unless u want it louder then just leave the catback.
Hey,
Im about to look into buying a dump and front pipe from my skyline (r33) along with a hiflow cat (or no cat :D). At the moment my exhuast is catback HKS Super Dragger and i was wondering if there is any different between me install brand names parts (HKS) or custum made parts.
Thanks Mike
Hey mike,
I just got my R33 and I have ordered afull turbo back system in mild steel with a stainless dump pipe and high flow cat and a LP02 muffler from x-force and they shipped to my muffler guy for $1000.00 I have since been told that the X-force stuff is of high quality.
A staainless dump pipe alone can be $250 - $500.
I will get it on on wednesday (12/05/04) and I will let you know how it goes.
Cheers,
J-Flash
Hey,
Thanks Mike
APC in Brisbane have an awesome dump/turbo pipe - I would nave installed this had I known about it. I got ripped by Subzero who put a ss dump pipe ($270) and once fitted said I needed a front pipe (they originally said I had a custom 3" front but when I measured it I found it was only 2"), quoted $170 and then hit me up for $310 (after it was fitted) because they miss quoted - bad business manners! Talk to Nick at APC he knows his stuff www.apc_racing.com.au
web site is www.apc-racing.com :headspin:
    • More than happy with the colour match Talking to the painter he recommended to give the top a few weeks for the paint to 100% cure prior to sealing it with the ceramic stuff Also, because why not..... I have a fancy pants Fluidampr harmonic balancer on order, the 2.5 engine uses the OEM 2.0 balancer off the old motor as the 2.5 balancer is a larger unit and doesn't fit clearance wise, which, because the two engines have different harmonics, isn't optimal, the OEM balancer does the job, but as the gear driven balancer in the bottom end is removed to fit a RWD application there is slightly more vibration, the Fluidampr helps with the harmonics that the gear driven balancer once took care of,  basically makes life easier on the oil pump and bearings when thrashing it around Hopefully the weather gets better soon because I'm keen for some cruising around, and currently, with the winds and storms we are getting, the amount of detritus being blown around from trees on the road isn't something I want to be driving around in
    • Meanwhile you could come down for a coffee tomorrow. Details in the events section
    • sorry dude i forget about the forum sometimes. sent you a pm
    • Hell yeah. It's not as if the path from front to rear is particularly squirrelly or otherwise difficult.
    • Hard line it, you will be thankful later on, if you car had hicas, use that as your return.
